EAGLE User Support (English) Position of pads
  • Views 314 views
Position of pads
is there a simple way to retrieve the position of a pads in the board view?
Marco
    autodeskguest over 13 years ago in reply to bmoe
    Il 09/04/2013 14:00, Matias Sjögren ha scritto:
    One way would be to attach a wire to the pad and then look at the
    preferences of the wire at the From/To fields.
    Yes, this is the workaround I currently use.
    I'm looking for a native solution.
    Other CADs allow the user to select any item of a part (pads, holes,
    etc...) in order to inspect their properties. It would be very easy to
    place a component using a pad as reference (without change the library
    of course...).
    Marco
  • bmoe
    bmoe over 13 years ago
    Hi.
    One way would be to attach a wire to the pad and then look at the the From/To fields in the preferences of the wire.
    /Matias
