EAGLE User Support (English) Moving Wires with ULP or SCR
  • Views 742 views
Is this possible?
also, is it possible to set any of the attributes of the objects in the ULP api?
UL_WIRE x1,x2,y1,y2 for instance ?  - it seems like its not, and I cant see how to use the MOVE command to move a wire around.
Rob.
    autodeskguest over 13 years ago in reply to e14 Contributor
    Hi, thanks for
    getting back,
    I currently do use the exit() to execute my scr, but I am unable to see
    how to move "wires" around with the scr. It seems only certain objects
    can be move with this command? or am I missing something?
    Rob.
    You need to think 'how do I do it when in the editor?' as that's the limit
    of your power.
    Trouble is, wires have no names so you cannot refer to them by name.
    In the editor you can MOVE a wire by clicking its ends or middle and drag
    it.
    You can put it into a group and move that group.
    So your ULP needs to be identify these same points and replicate the same
    actions. You can MOVE(current point)(new point)
    e.g MOVE (0 0)(1 1)
    Trouble is you need to be sure there is no other object at the pickup point
    as that may be picked up. Sometimes you may need to hide the other layers.
    Normally the precision of the specified points will assure that the desired
    object point snaps to the cursor.
    You have to remain aware that in the editor you cannot get at the wires in
    an element(package). You need to manipulate those in the library. That
    said, another option is to manipulate the XML of the board file.  You still
    have the challenge of identifying the wire.
    Something that may work for you is this:
    You could first put the wire of interest into a group by itself. you can
    then detect that wire in the ULP as it is ingroup()
    Eagle permits you to set up a context menu(right Click). See HELP >SET>
    Context Menus. Set that up for a wire and it will be the only object
    grouped at that time so you can detect the wire and discover its points.
    Careful of routed traces as they look like wires but you cannot move the
    end attached to a pin.
    Again, practice what can be done manually in the editor to understand what
    you can automate.
    All the best
    Warren
    e14 Contributor over 13 years ago in reply to autodeskguest
    Hi, thanks for getting back,
    I currently do use the exit() to execute my scr, but I am unable to see how to move "wires" around with the scr. It seems only certain objects can be move with this command? or am I missing something?
    Rob.
    Hi Rob
    No,unfortunately. You can only read them. When you exit the ULP you run
    commands directly in the editor from the final exit("commands string") or
    fire off a script you can build and save from within your ULP calling the
    script the same way i.e. exit(script 'MyScript'). The script will often
    have speed advantages.
    All the best with the Python approach. I'm interested to see what develops.
    Warren
