EAGLE User Support (English) Complex SMD pad
  • Subscribers 187 subscribers
  • Views 289 views
Complex SMD pad
eugeny
eugeny over 13 years ago
Hello, please help finding the solution.
I need to create a complex pad configuration with library editor. This pad will consist of two joined rectangles of different sizes. If I just create two joined/overlapping pads, DRC gives "overlap" error. How can I tell the system that these two rectangles represent one signal? Thank you!
    you!
    http://www.element14.com/community/message/74749#74749
    You can take a PAD or SMD as a basis an then use a POLYGON to draw the
    final contour of your complex pad. If the SMD or PAD is inside the
    polygon EAGLE (from v6 on) recognizes this as belonging to the same
    signal. Be sure to draw solder stop and solder paste (if any)
    separately.
    Richard Hammerl
