EAGLE User Support (English) Terminate eagle from an ULP?
  • Subscribers 187 subscribers
  • Views 573 views
I try to generate a bom from the command line. bom_ew.ulp calls exit(). The
command line is
'eagle -C "run bom_ew bla " qm07_blm.sch'
This created the wanted output file, but eagle is keeping running. How can I
get the ULP or the ULP invocation to terminate eagle?
Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
Tel. 06151 162516 -
Fax. 06151 164321 -
    autodeskguest over 13 years ago in reply to autodeskguest
    René König <rk@tbkoenig.de> wrote:
    try: 'eagle -C "run bom_ew bla; quit" qm07_blm.sch'
    Thanks!
    I searched for "exit" and "terminate" but forgot quit...
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Am 25.04.2013 17:18, schrieb Uwe Bonnes:
    command line is
    Try the exit command with
       exit("quit");
    I don't know whether this works under your circumstances, but generally
    it should.
    Andreas Weidner
    Rene
