EAGLE User Support (English) Opened Eagle 5.11 board file with 6.4.  Saved with 6.4.  Now can't open with 5.11.
  • Views 1044 views
  • eagle_software
I opened an existing board design with Eagle 5.11 with Eagle 6.4.  I saved the file <by accident> and now cannot open again the file with Eagle 5.11.  Error Message is "Invalid data in file c:\users......"  Is there a way to go back.  I downloaded Eagle 6.4 just to see what has changed and forgot to switch back to 5.11 prior to working on real projects.  I do not want to update to new version of Eagle at this time.  Thanks
    e14 Contributor over 13 years ago in reply to autodeskguest
    Thank you for the assistance.  Back up and running again.
    autodeskguest over 13 years ago in reply to autodeskguest
    this time.  Thanks
    Simply use your backup.
    (File formats are incompatible, this is well documented. If you want
    to avoid such problems, use different paths or work with copies of
    your design files.)
    Tilmann
    If you do not formally backup then Eagle may have an older backup. Open the
    folder that V5 fetched the file from and check out the files with file
    extentions like myfile.b#1 and myfile.s#2. There are likely 9 for the board
    and 9 for the schematic.
    They are previously saved versions. Find the lowest numbered pair that are
    not XML when you view them in an editor like notepad. Then  rename the
    extentions as .brd and .sch files. Open them with v5 and bring them upto
    date.
    HTH
    Warren
    news.cadsoft.de
    time.  Thanks
    (File formats are incompatible, this is well documented. If you want to
    avoid such problems, use different paths or work with copies of your
    design files.)
    Tilmann
