EAGLE User Support (English) Eagle 6.4.0 - consistent crashing
  • Views 811 views
Greetings. Recently got in to using Eagle (ver 6.4.0) and so far I've been
fairly unhappy with how frequently it crashes. Usually the crashes occur
during relatively simple changes. For instance, yesterday I created a text
block with a single letter in it to place on the silkscreen, and if I tried
to change the properties of that text block (text size, orientation, etc),
Eagle would crash. Also, if I tried to change a via size or shape, same
crashing issue. The board I was working on yesterday is fairly small, 7mm
diameter with .005" traces, .011 holes, etc, but I can't imagine that Eagle
can't handle this. I've heard good things about Eagle, and I can't seem to
find anything online referencing the issues I am having, so it seems like I
might be doing something wrong. Any ideas? Should I uninstall/reinstall?
Any feedback would be appreciated.
Chris
    Thanks Jorge, I will give this a shot
    autodeskguest over 13 years ago in reply to e14 Contributor
    On 5/1/2013 1:24 PM, Christopher Phelan wrote:
    Sorry, thought I put that in my first message. Windows 7 64 bit.
    Hi Christopher,
    I hope you're doing well. We're running into some crashes we can't
    reproduce on 64-bit machines.
    We're looking into solutions for this for a future release. In the
    meantime a couple of things you can do to minimize the crashes even
    though they will continue until we get this resolved.
    - Save all of your personal work to the eagle folder in Documents, this
    is a safe area void of any restriction on behalf of the OS. This means
    schematics, boards, and libraries as well as scripts and ULPs you might
    make.
    - In some cases setting EAGLE to run in administrative mode can help.
    Best Regards,
    Jorge Garcia
    Chris
    Hi Chris,
    What's your computer setup? Do you have a 64-bit machine? Windows , Mac,
    Linux?
    The changes you're trying to make are nothing outside of EAGLE's
    capabilities.
    Let me know what you find.
    Best Regards,
    Jorge Garcia
