EAGLE User Support (English) Design Rules
  • Subscribers 177 subscribers
  • Views 200 views
Design Rules
autodeskguest over 12 years ago
When I open a project and load a set of design rules (from, say, my
private rule set), are these rules statically or dynamically linked?
In other words, if I have ruleset1 loaded and change ruleset1, are the
changes reflected in the project immediately (subject to actually
running a check, of course) or must I re-load the rule set for the
changes to become active?
Many thanks,
Bob
    Robert von Knobloch wrote:
    Many thanks,
    Bob
    H Bob
    As soon as you apply a design rule change it is in effect immediately.
    Some of the DRC settings change your board the moment they are applied. e.g
    Restrings, solder stop and paste
    Some are applied as you further create your board. e.g. width and clearance
    when using the auto router
    The remaining ones come into play when you run a DRC check
    HTH
    Warren
    news.cadsoft.de
