EAGLE User Support (English) Error: Unknown Command: Layers
  • Subscribers 178 subscribers
  • Views 395 views
scott216
scott216 over 12 years ago
In the package editor (Eagle 6.4 on Mac 10.7.5), I tried opening some
packages from the Adafruit Eagle library
(https://github.com/adafruit/Adafruit-Eagle-Library) and on many if them I
get this error: Line 290 Unknown Command: Layers
For example, opening the package ARDUINOR3_ICSP give me this error.
Here's a screenshot of the error:
http://www.flickr.com/photos/37101040@N00/9372199817/
Anyone know why I'm getting this?
    autodeskguest over 12 years ago
    them I get this error: Line 290 Unknown Command: Layers
    Hi
    I downloaded that file and have no issues using  v6.3.3. with Windows.
    Make sure you used the correct techinque to get the file from Github.
    Inspect the file with a text editor that can displays the line numbers and
    see if it is corrupt around line 290.
    Line 290 is in package EG1213 but that opens OK for me.
    The  file has 49,457 lines so ensure yours does.
    Some uses had issues with Macs crashing with v6.4 so if the above does not
    get you past the rpoblem I would download the recent beta 6.4.5 and give
    that a go.
    HTH
    Warren
    news.cadsoft.de
    Woops
    If I read the error message correctly I see Eagle is reporting an issue with
    the eagle.scr file.
    That file lives in the scr folder of your installation. My eagle.scr file
    is not 290 lines long, maybe yours is. So check that out.
    Good luck
    Warren
    news.cadsoft.de
  • scott216
    scott216 over 12 years ago in reply to autodeskguest
    I found the problem.  I got eagle.scr file from a website and one word,
    "layers" of a comment had wrapped to the next line.  I fixed it with
    textedit and the error is gone.
