EAGLE User Support (English) oh dear...need bottom & top layer changing....
  • Replies 9 replies
  • Subscribers 190 subscribers
  • Views 1143 views
So after putting the finishing touches to my pcb design on a long journey, I'm at the point where I can almost submit to a Chinese fab house ...but I've just found out that most aren't keen (read won't) to do a bottom silk screen....and the way I've done my board, a bottom silkscreen is essential (the silk screen will aid installation for those not familair with the pcb) - now as it goes, I don't need a top silkscreen, so I'm thinking that really I would like to  simply call my bottom layer the top layer & my top layer the bottom layer.
My new top layer (old bottom layer), can then have a silkscreen...in theory, it ought to be simply.
Now I've seen some ulps that swap layers, but frankly my brain starts hurting at what cvould go wrong (for example drill holes being drille din the wrong location) ...I've also read of some folks  'mapping' the eagle layers in the cam jpb to their own layers of choice....I feel comfortable doing neither.
Which is the least worst way of proceeding here?!!
    autodeskguest over 13 years ago in reply to e14 Contributor
    On 08/01/2013 10:08 AM, Robert Smith wrote:
    Thanks guys...I'll see if I can find a fab house that will print on the
    bottom layer (because mirroring - or the notes method - could end up as
    a costly rerroneous outcome!)...the thing is, this needs to be a low
    cost pcb, as I intend testing the market with a low cost product!
    I've had good results from PCB-Pool. They accept Eagle .brd files
    directly (no Gerbers!), offer a customized DRC file for Eagle to avoid
    incompatibilities, and I know they'll print on either side.
    They have several fab sites (Germany and South Africa, and maybe a new
    one in California), but final shipments appear to originate from
    Shannon, Ireland. If you're in the UK, that'll save you long delivery
    times and save you on shipping.
    -Reece
    autodeskguest over 13 years ago in reply to dukepro
    Chuck Huber wrote on Fri, 02 August 2013 01:30
    On 07/31/2013 09:03 PM, Warren Brayshaw wrote:
    It seems to me you could simply rename the gerber files so they
    stack up in
    the reverse order. Remembering to change your notes to the board
    house.
    That will only work if you insert your components from the same side.
    Not only that but the lettering on the silk screen would be mirrored.
    But I'd checkout other board houses.  We generally use Advanced
    Circuits, 4pcb.com.
        - Chuck
    The OP wanted to call the bottom, top and top, bottom. so the factory sees
    bottom silk as top silk. Phyically the board was not changed
    Gerbers are top down view. It's the board house that applies the required
    mirroring for a layer. It has to be this way. Think of layer 2 of 4. The
    litho for layer 2 needs to be different depending on the board stack up ie
    Laminate/prepreg/laminiate or Prepreg/laminate/prepreg
    HTH
    Warren
    e14 Contributor over 13 years ago in reply to shabaz
    Thanks guys...I'll see if I can find a fab house that will print on the bottom layer (because mirroring - or the notes method - could quite easily have a costly erroneous outcome!)...the thing is, this needs to be a low cost pcb, as I intend testing the market with a low cost product!
    michaelkellett over 13 years ago
    Unless you really can't pay any more I suggest you find a board maker that will do what you want:
    Try www.pcbtrain, eurocircuits, pcbpool etc.
    shabaz over 13 years ago in reply to autodeskguest
    I think he may also want to 'flip' the detail as Chuck mentioned, otherwise it may cause confusion for the manufacturer (not sure, I've never had this issue to deal with! :-) unless he can explain it in the notes successfully as you say.
    Or, if the files have already been generated, a program like 'gerbv' will allow you to flip gerber files, or the manufacturer can do it themselves - but again, it's down to how well he can explain it to the manufacturer.
  • dukepro
    dukepro over 13 years ago in reply to autodeskguest
    It seems to me you could simply rename the gerber files so they stack up in
    the reverse order. Remembering to change your notes to the board house.
    Circuits, 4pcb.com.
        - Chuck
    If it's a multi layer board watch out for the drills of vias that dont go
    from top to bottom.
    HTH
    Warren
  • dukepro
    Make sure all your components are unlocked.  Group all, and mirror the
    group.  Then reposition the board back into Quadrant 1.
    Have you tried that yet?
        - Chuck
    I have never had a problem with this.
    They do charge more, but not much.
    You might want to check other boardhouses.
    -D
