EAGLE User Support (English) Have a question about CadSoft EAGLE?  Ask our Expert, Jorge!
  • Replies 126 replies
  • Subscribers 200 subscribers
  • Views 10911 views
  • our
  • have
  • expert
  • eagle?
  • jorge!
  • ask
  • a
  • cadsoft
  • about
  • question
Jorge_Garcia
Jorge_Garcia over 13 years ago
If you have questions about CadSoft EAGLE, please click here to post your question!
If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Jorge Garcia
I'm a young engineer with extensive experience working on EAGLE. My interests include Power Supply design and LED solid state lighting, and I'm always impressed by a well designed PCB.
If not already, you'll need to
image or image
to ask your question.
Otherwise, click reply below.
  • nschreiber0813
    nschreiber0813 over 12 years ago
    Dear: Jorge
    Sorry about my last reply I accidentally replied to Jeremy instead of you. I have a question about eagle. Recently I finished my first PCB and I am in development for my second PCB. I have never used a micro-controller before and I am stuck on a problem. I am trying to make a line following robot but it needs a mother board. The mother board is running into an error where I can't find where to attach the USB port to the micro-controller. Can you please help me? Also go to here if you can't find atmega103 PDF http://www.atmel.com/Images/doc2467.pdf
    HI there this is salman here i am looking to buy some units of EA-PS 9080-100
    POWER SUPPLY, 1CH, 80V, 100A, ADJUSTABLE i need answer to the following questions
    1. Calibration Test Data
    2. Country of Origin
    3. Publication and Literature is essential requirement
    4. Standard Warranty is required.
    e14 Contributor over 12 years ago in reply to autodeskguest
    Thank you very much! I will try that ASAP
    autodeskguest over 12 years ago in reply to e14 Contributor
    On 4/11/2014 6:44 AM, Giorgos Kosmidis wrote:
    Hi
    Is there a way to clean holes and vias when exporting pcb image?
    I do that in photoshop now. I drill holes manualy and if i leave
    wiring/coper in the via/hole then the drill cannt be centralized by
    hand.
    Hi Giorgos,
    I hope you're doing well. I personally have used the cam2image.ulp with
    great success. The ULP turns gerbers into high resolution files. On
    these images the via and pad holes are cleared making it easy to see
    where to make the holes.
    hth,
    Jorge Garcia
    Hi
    I do that in photoshop now. I drill holes manualy and if i leave wiring/coper in the via/hole then the drill cannt be centralized by hand.
    Thank you
    Hello Jorge,
    I am doing fine and feeling great! Soaking up a lot of this sunshine in my sunroom laboratory from a long wintry hades.Thank you for asking. Same to you Sir. I appreciate your expertise as well as the fast response. Jorge, may you have a wonderful rest of your day followed by a great weekend!
    ~Emjay
  • AnalogNotes
    AnalogNotes over 12 years ago in reply to autodeskguest
    Jorge Garcia wrote:
    I'm sure it's the same with other users who don't use the Element-14
    forum interface. I participate in the forum using the NNTP reader in
    Thunderbird. The interface on Element-14 I guess just assigns messages
    from the NNTP server to be Cadsoft Guest.
    If anybody has found anyway around that I would be more than happy to
    know how to do it.
    I don't know for certain, but I think somehow there might be some kind of coordination between the EAGLE Central account and the Element14 account.  When I post from either place, it seems to be correctly attributed.  (For example, I posted this from the EAGLE Central site: Re: Essay on the Eagle Interface   You can tell by the signature block where it came from.)  You might contact James to see if that's it.  (NOTE: I don't access the NNTP groups directly.)
    I'd love to see a solution to posting lists and source code snippets so that they can be read on both/either Element14 and EAGLE Central.  For example, I posted these Element14 links from Element14:
    Element14: Re: Essay on the Eagle Interface
    But nothing showed up on the NNTP feed:
    EAGLE Central Forums: eagle.suggest.eng » Essay on the Eagle Interface
    Same for source code snippets.  Github gists look good on Element14, but don't seem to get propagated to the NNTP groups...
    autodeskguest over 12 years ago in reply to gwideman
    On 4/8/2014 8:53 PM, Graham Wideman wrote:
    Emjay:
    Jorge often posts as "CadSoft Guest", so actually the reply you read may
    have been from him.
    Hi Graham,
    know how to do it.
    Best Regards,
    Jorge Garcia
    Now I asked if the resizing of the grid will affect the component's
    size? which I never got a response back from Chuck.
    I appreciate dealing with you on this subject being you are kind enough
    to respond when you can.
    I built the component using 1 mil increments on the symbol instead of
    keeping it at 0.1". Chuck's instruction set is clear I only need to know
    will it affect the size of the component.
    I also need to know why is it that when building a component one must
    use 0.1" when like in my case the component is a micro-smd which the
    package measures in millimeters and the pads measure in mils, which is
    why I used mils?
    I built the component's pads using mils(as the pads are 9x12mils in
    dimension) but I am instructed by Chuck to built the entire symbol using
    0.1" which doesn't make sense to me.
    Hi Emjay,
    I hope you're doing well. Chuck's suggestion is correct and here's the why.
    As far as the schematic symbol goes, its not necessary for it to match
    the physical parameters of the real component. The goal with the symbol
    is to aid understanding of the design.
    In the schematic the 0.1"(2.54mm) grid recommendation comes up because
    all of the symbols in EAGLE's default libraries are made to that grid,
    so if you use a different grid spacing the pins aren't going to line
    properly which will make connections almost impossible. In order for a
    connection to be valid in the schematic nets must start and end on very
    exact points if you're off by a hair the connection won't be defined. By
    using a 0.1" grid you insure that your pins are always on grid and your
    connections are reliable.
    The grid in the schematic has no bearing on the grid in the layout. For
    the layout you need to use whatever grid is convenient and the package
    you use for a component must match it's physical parameters precisely in
    order to make a useable board.
    As you can see the grid in the schematic will have no effect on the
    package size so your layout will still be accurate sized even if your
    schematic symbols are larger for the sake of readibility and understanding.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    On 4/8/2014 12:38 PM, Badri Glonti wrote:
    I have to do a project with raspberry pi, could you help me and advice
    me which robot will be compatible with it?
    I want to buy a cheap robot which I can hook to the raspberry pi,
    nothing something advanced.
    Hello Badri,
    I hope you're doing well, I'm afraid this is not the correct forum to
    ask for Raspberry Pi help. I enjoy working with the Pi myself, but I am
    by no means an expert. I would suggest you post your inquiry on the
    Raspberry Pi forum, where I'm sure you'll receive lots of useful
    suggestions.
    hth,
    Jorge Garcia
