EAGLE User Support (English) Have a question about CadSoft EAGLE?  Ask our Expert, Jorge!
  • Replies 126 replies
  • Subscribers 200 subscribers
  • Views 10908 views
  • our
  • have
  • expert
  • eagle?
  • jorge!
  • ask
  • a
  • cadsoft
  • about
  • question
Jorge_Garcia
Jorge_Garcia over 13 years ago
If you have questions about CadSoft EAGLE, please click here to post your question!
If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Jorge Garcia
I'm a young engineer with extensive experience working on EAGLE. My interests include Power Supply design and LED solid state lighting, and I'm always impressed by a well designed PCB.
If not already, you'll need to
image or image
to ask your question.
Otherwise, click reply below.
    Am 22.05.2014 06:11, schrieb J Chop:
    Hi Jorge,
    I am a new user to Eagle and I am having a hard time with a schematic. I
    had created some components which I recreated after I learned the hard
    lesson of schematic view's limitation to 0.1" grid snapping image
    After implementing the new components and running ERC, all nets on one
    IC still show "net N$ overlaps pin". What can I do to fix this?
    Thanks in advance!
    http://www.element14.com/community/message/113585
    You can use in symbol-editor :
    RUN snap-pin-in-symbol.ulp
    in schematic-editor:
    RUN snap-on-grid-sch.ulp
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    EAGLE V6.5 availabe now!
    Hi Jorge,
    I am a new user to Eagle and I am having a hard time with a schematic. I had created some components which I recreated after I learned the hard lesson of schematic view's limitation to 0.1" grid snapping :-(
    After implementing the new components and running ERC, all nets on one IC still show "net N$ overlaps pin". What can I do to fix this?
    Thanks in advance!
  • bhodder
    bhodder over 12 years ago
    I am working in a library trying to create a simple oval pad. When I switch the pad to oval it no longer shows up. How do I get this to show back up. Also is it possible to create a long pad like a oval pad but with flat caps?
    Blake
    autodeskguest over 12 years ago in reply to e14 Contributor
    Hi Sean,
    We have a list of users we usually recommend when work like this comes
    up. I personally can't get involved with the project, but send me an
    e-mail to support@cadsoftusa.com and I'll forward the list to you.
    Best Regards,
    Jorge Garcia
    dear mr. garcia wow thats so exciting that you think one it's a good idea and two doable awesome the whole reason i even asked you the question is because of your love of l.e.d's i know they work very good and there are alot on the market but i would like to design my own light also but first the timer i also want them to have a remote in case you want to turn things on or off without exposing your plants to light during the flower period so where would you advise me to start i really only have around ten thousand to work with at the moment but computer engineering stuff i would have long learning curve to get the info i need to retain to do this kind of work so if you could give me some more advice if you would like to work on this with me or you know of someone that deserves to be a partner with me on this please let me know i do need help to bring this to market and thank you so much for your reply so happy to hear it
    Hi Sean,
    I hope you're doing well. You've mentioned that you lack the know how
    and the equipment necessary to execute the ideas you've described. I do
    think they're feasible and could be produced.
    The tradeoff now becomes time vs money. Do you take the time to get the
    know how and the equipment, to then spend the time developing the idea,
    prototyping, debugging, etc. Or do you spend the money to higher someone
    to take the idea to fruition. You're the one that has to make that decision.
    If you're going to get the know how yourself, I'd recommend starting
    with an Arduino it's probably the shortest path to a finished solution.
    Learning about Safety is also important since you'll be dealing with
    110V/220V AC. This would be a very basic start, but it's only the first
    crumb.
    hth,
    Jorge Garcia
    dear mr. garcia well sir i have an awesome idea but i don't have the know how nor the equipment to get it done so i would like to run my idea by you and see if it can even happen and get it written down sort of a digital patent to say it was my idea first i guess anyways here's the idea i want to build a better timer i want it to be about the size of a regular wall plug in multi-outlet and i want about 10 plug in's that can be controlled indipendtantly from the other's by inter facing with a computer i think the way i worded that is right so when the buyer gets his timer home he plugs the timer into his computer and he will enter the time and date he wants the timer to be at and then he will be able to chose from a database like list of time settings for each plug in the device and be able to set the time to come on or go off up to every minute of the day and be able to set it months in advance if they so choose so they can have different plugs come on at different times then the cord they use to interface with the laptop or home computer they plug it into a wall adapter to power the device so there is the beginnings of what i think will be the only timer people that are serious about there times like i am i also want to design my own l.e.d. lights to put on the market they will have built in timers of course and a life meter that tells the person how many hours that device has been used and make them 110 / 220 i also have a few other ideas about this but let's see if you even reply to my pourly written letter but if you do read and think i could get this thing going please let me know where to start and thank you very much and have an awesome life   seanmcevers@yahoo.com
    autodeskguest over 12 years ago in reply to nschreiber0813
    On 4/29/2014 1:34 PM, Noah Schreiber wrote:
    The problem is that I am trying to connect USB-MINI B to atmega103 in
    schematic. Also I am using micro-controller atmega103 not atmega128. So
    please help me.
    Hi Noah,
    The problem still stands, in order to know where to connect the various
    USB-MINI pins; you need to know what pins of your micro are going to
    handle USB communications. Since the ATMEGA103 doesn't have a USB
    peripheral there's no easy way to define what needs to connect to what.
    Perhaps you're using the connector just for power, if that's the case
    you would connect pins 1 and 5 of the USB connector to the appropriate
    rails.
    To define those connections you would use the NET command on the
    schematic and the ROUTE command on the board.
    hth,
    Jorge Garcia
  • nschreiber0813
    nschreiber0813 over 12 years ago in reply to autodeskguest
    Dear: Jorge
    I would like to say first of all thank you for responding to my message. Second of all that is not the problem. You said to me that...
    Hi Noah,
    The issue here is that this chip (ATMEGA128) doesn't have native USB
    support built-in. If you wanted it to hook up to USB you would have to
    use a USB-Serial chip which is what the original Arduino's used. If you
    intend to use this processor and need USB connectivity you'll have to
    use a USB-Serial chip like the ones made by FTDI and others.
    hth,
    Jorge Garcia
    P.S This is not my area of expertise so if anyone has any corrections
    feel free to post them.
    The problem is that I am trying to connect USB-MINI B to atmega103 in schematic. Also I am using micro-controller atmega103 not atmega128. So please help me.
    On 4/29/2014 10:19 AM, Noah Schreiber wrote:
    > The mother board is
    running into an error where I can't find where to attach the USB port to
    the micro-controller. Can you please help me? Also go to here if you
    can't find atmega103 PDF http://www.atmel.com/Images/doc2467.pdf
    Hi Noah,
    hth,
    Jorge Garcia
