EAGLE User Support (English) Have a question about CadSoft EAGLE?  Ask our Expert, Jorge!
  • Replies 126 replies
  • Subscribers 200 subscribers
  • Views 10956 views
  • our
  • have
  • expert
  • eagle?
  • jorge!
  • ask
  • a
  • cadsoft
  • about
  • question
Jorge_Garcia
Jorge_Garcia over 13 years ago
If you have questions about CadSoft EAGLE, please click here to post your question!
If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Jorge Garcia
I'm a young engineer with extensive experience working on EAGLE. My interests include Power Supply design and LED solid state lighting, and I'm always impressed by a well designed PCB.
If not already, you'll need to
image or image
to ask your question.
Otherwise, click reply below.
  • dukepro
    dukepro over 12 years ago in reply to e14 Contributor
    Jorge,
    I'm trying to draw a hash filled semicircle with the two corners
    mitered.  Clicking on a polygon's vertex gives me an error beep.
    Is it possible to miter the corners of a polygon?
    The only workaround I have found is to move the vertex up, then split
    the straight line cutting across the semicirle to leave a 45 degree
    segment joining the end of the diameter line to the end of the arc.
    Then I edit the properties of the 45 deg line and give it a 90 degree arc.
        - Chuck
    autodeskguest over 12 years ago in reply to e14 Contributor
    On 3/21/2014 3:07 PM, Al Lunev wrote:
    Hi, Jorge! I've got the up-to-date light edition and only one question:
    just can't add smd-ipc library!!! Only this library. I use "Use library"
    to add the library to the "Add" window but I can't add it. I'm sorry for
    my english!
    http://www.element14.com/community/message/106980
    That library only contains packages. Since these can't be brought into a
    schematic, EAGLE doesn't include the library in the ADD dialog for the
    schematic editor. If you try it from the board editor you will see that
    it works.
    Best Regards,
    Jorge Garcia
    Hi, Jorge! I've got the up-to-date light edition and only one question: just can't add smd-ipc library!!! Only this library. I use "Use library" to add the library to the "Add" window but I can't add it. I'm sorry for my english!
    e14 Contributor over 12 years ago in reply to autodeskguest
    Hello, Jorge,
    I have a question but had already started a thread when I saw your post.  I have used several CAD systems years ago including PCAD, ORCAD and TangoPro but am having a small problem getting started in symbol creation.  Perhaps you could comment here:
    http://www.element14.com/community/thread/32402/l/single-selection-of-neighboring-adjacent-items-on-a-worksheethttp://www.element14.com/community/thread/32402/l/single-selection-of-neighboring-adjacent-items-on-a-worksheet
    rather than me reposting.
    Also, I have requested a contact with you re a possible consultation re power supply design, FYI.
    David
    On 3/19/2014 10:33 AM, Klas Larborn wrote:
    Hi Jorge,
    I get the message below when trying to import my design from LTC Spice.
    Importing LTC Spice default design exemples seems to work though.
    (www.element14.com/.../Eagle
    6.5 Errormessage.bmp)
    Hi Klas,
    Look at your LTSpice design. Do you have any custom-made components in
    it? Did you remember to place GND symbols in your LTSpice schematic?
    If you have custom LTSpice components then you have to make a matching
    EAGLE part. See the Simulate with EAGLE webinar up on youtube.
    hth,
    Jorge Garcia
    Hi Jorge,
    Fullscreen contentimage_176348.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    What could be the reason?
    Klas
    autodeskguest over 12 years ago in reply to bhodder
    Blake,
    the contact for libraries from element14.com is:  CAD_Tech@element14.com
    (mailto:CAD_Tech@element14.com)
    Richard
    http://www.element14.com/community/message/106050
    On 3/11/2014 9:10 AM, Blake Hodder wrote:
    I should specify first that it is one the libraries by element14, is it
    still the same contact?
    Hi Blake,
    Thanks for specifying. The element-14 libraries have a different
    contact, usually when you download these they'll have a readme file the
    give you the contact information for the department that made those. The
    element-14 libraries are not made in direct association with Cadsoft,
    that's why they have a different contact.
    hth,
    Jorge Garcia
  • bhodder
    bhodder over 12 years ago in reply to autodeskguest
    I should specify first that it is one the libraries by element14, is it still the same contact?
    Blake
    Hi Blake,
    Contact librarian@cadsoft.de. Make sure to provide
    documentation(datasheet, IPC image, etc.) to demonstrate the error in
    the library.
    hth,
    Jorge Garcia
    Cadsoft Computer
