EAGLE User Support (English) Engineering notes within Eagle
  • Subscribers 186 subscribers
  • Views 907 views
What:
Would like to see a feature enabling adding (engineering) notes.
How:
Basically text with an icon to expand/hide/show text and small header text above. So "add" note, then a small popup window, add a title, write formatted text, paste in graphics. etc. User can "hide" and "show". In hide state only the icon is shown.
Suggested icon is just any standard icon for an open and closed file/document.
Why:
To keep notes regarding component values calulated, op-amp design, filter values, oscillator design, spesific notes regarding tips to the one dosing PCB layout (keeep that line short to pin so and so, place compoent so and so), stripline calculations and what not..
The note feature should preferably have the possibility to add/paste graphics, like from app-notes in order to allow pasted informstion from chip vendors (regaarding reference design, recommended component values etc..)
Current text "T" tool is also very limited, takes to must space on the drawing and is not usefull when adding documenation. Using external word processors is also an possible option, but then the document it not "linked" to or close to the schematic in any way, so why not add some (engineering) note features withing Eagle?
Thanks!
  • AnalogNotes
    AnalogNotes over 12 years ago
    I keep a notes.txt file in each project directory myself.  Unfortunately, the "edit" command doesn't work on text files, so I wrote a ULP that opens the file with write.  Put the code below into a file (I call it "notes.ulp") in your ULP directory, then you can type "run notes" when you're editing either the schematic or the board.  You can add this ULP to the commands text menu if you want to click instead of type.  (Of course, you can also click on the notes.txt file in the EAGLE control panel if you have that displayed...)
    if (schematic) {
      schematic(SCH){
        string directory = filedir(SCH.name);
        string message;
        sprintf(message, "write %snotes.txt", directory);
        system(message);
    if (board) {
      board(BRD){
        string directory = filedir(BRD.name);
        string message;
        system(message);
  • CSWalt
    CSWalt over 12 years ago in reply to AnalogNotes
    if (schematic) {
      schematic(SCH){
        string message;
        system(message);
    if (board) {
      board(BRD){
        string message;
        system(message);
    http://www.element14.com/community/message/87335#87335
    EAGLE also supports DESCRIPTION files for projects.
    See out Arduino sample project. In the CP click on the project folder.
    Then you see a description for Arduino in the preview.
    It displays the HTML content in the file DESCRIPTION.
    You can edit it by rightclicking on the project folder.
    You can use that the same way for your projects easily.
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    Former Member over 12 years ago in reply to AnalogNotes
    This worked for me, just was I was looking for!
    Invoking the WordPad editor with "write.." (in Windows) also allowed my to add/paste inn stuff from from chip vendors/reference design etc.
    I did change the line
    ..sprintf(message, "write %snotes.txt", directory); ... to sprintf(message, "write %snotes.txt", directory); ...
    to
    .. sprintf(message, "write \"%s\"notes.txt", directory); ...
    To escape white space in my directory and file names.
    Thanks!
