EAGLE User Support (English) EAGLE CAD disappearing libraries & disappearing parts
  • Subscribers 187 subscribers
  • Views 1195 views
Some time ago I created and saved a new part in an existing library that comes with EAGLE.   The library is "resistor-bourns.lbr".     I created a new symbol and footprint for a trimmer resistor, and since it was by Bourns, it made sense to save the part in that library.    Then I went about designing the rest of the board and everything went perfectly well.
When I opened up EAGLE CAD today, I noticed I could not find the library "resistor-bourns.lbr"  anymore.   However the parts I placed in my previous design are still present in both schematic/layout;  a query on the device properties still references "resistor-bourns.lbr" in the information window.
However, "resistor-bourns.lbr" is entirely missing from the library list.
I thought perhaps this library was deleted or moved by accident.  So, I restored the file resistor-bourns.lbr  from a backup to the correct EAGLE CAD directory, restarted the entire PC and EAGLE CAD, and went to look in that library now that it appears in the main Control Panel > Libraries entries.
The new part I had added is still missing.  Mysteriously, the part still appears in my schematic/layout of an older design.
Does anyone have any idea what is going on here?  Much thanks if you can lead me to a solution.
    autodeskguest over 12 years ago in reply to autodeskguest
    Am 07.10.2013 07:35, schrieb Lorenz:
    comes with EAGLE.
    bad idea! never ever use original eagle libraries to store you own
    creations. They will disapear when an eagle upgrade overwrites the
    library.
    information window.
    Eagle copies the library entries for parts used in a design  into the
    brd/sch files.
    list.
    Libraries entries.
    backup from before you created the part?
    In addition to the above said, you can export the library parts from
    your your board into a new library (export library.ulp). There you will
    find your created part. If you insist on "bourns", name this library
    "bourns-lorenz" i.e. image
    Joern Paschedag
    comes with EAGLE.
    library.
    information window.
    brd/sch files.
    list.
    Libraries entries.
    Lorenz
