EAGLE User Support (English) Pour is Applying Spacing Rules to Dimension Layer
  • Subscribers 187 subscribers
  • Views 618 views
  • spacing
  • layout
  • pcb
  • pour
  • clearance
I did a ground layer pour and it is spacing itself away from the dimension layer.  I would expect by default pours would only space themselves away from conductive layers of different NET or board edges.  The dimensions aren't usually physically printed so I did not expect this to happen.
In any case, can I fix this the rules so that this doesn't happen?  Any instructions are greatly appreciated.
-Nathan
    autodeskguest over 13 years ago in reply to e14 Contributor
    Il 24/10/2013 22:46, Nathan Meryash ha scritto:
    I thought DImension Layer = Use for Dimensions not outline.
    You should use the Measures one (or the Document one if you prefer).
    The
    nomenclature is not intuitive but it is what it is, thanks for the
    headsup.
    I might agree. But have you ever read the "layer" page in the manual (F1) ?
    There is a table which reports all layers with a description about their
    use.
    Marco
    e14 Contributor over 13 years ago in reply to autodeskguest
    Thank you.
    I thought DImension Layer = Use for Dimensions not outline.  The nomenclature is not intuitive but it is what it is, thanks for the headsup.
    Would measurements be the appropriate layer to assign to what I am refering to as dimensions?
    -NGM
    dimension layer.
    Well, yes, of course.
    And what, pray, do you think the difference is between "board edges" and
    "the dimension layer"?
    this to happen.
    The dimension layer doesn't need to be printed because it's where the
    board ends. That's what it does.
    If you're putting ANYTHING in the dimension layer that is not the edge
    of the board, then you need to fix what you're doing.
    Annotations and markers go in one of the "document" layers, because they
    are pure documentation. That includes any annotations saying "this is
    five inches".
