EAGLE User Support (English) Removing Pad Names from Schematics
  • Subscribers 178 subscribers
  • Views 953 views
Hi all,
I have created a custom symbol for an Eagle project ( nothing more interesting than a SPST switch), but I would like to not have the pad names (PCB footprint names) on the schematic. Much like how the default capacitors, resistors, etc are.
However, I cannot find anywhere which tells me how to do this.
If anyone could offer some help, I would be very grateful.
Many thanks for your time,
Sparky
    autodeskguest over 12 years ago
    HELP PIN and note the function option.
    Former Member over 12 years ago in reply to autodeskguest
    I'm sorry, I don't quite understand.
    autodeskguest over 12 years ago in reply to Former Member
    http://www.element14.com/community/message/95496
    When you're creating pins on a schematic symbol, there's a pull-down box
    option for pin/pad/both/none in the toolbar. Your pull-down box was set to
    'both' when you added the pins to your symbol. Read 'help pin' for details,
    then go back to your symbol and change the pin. Then update the library in
    your schematic.
