EAGLE User Support (English) How to route a trace without airwire
  • Subscribers 178 subscribers
  • Views 1454 views
  • trace
  • airwire
  • route
remkok
remkok over 12 years ago
I would like to use on both top and bottom layer the same connection. This because there is a current of 10A max possible. When I started te route there was an airwire. This I used for routing the top layer. Bur know I want to route the bottom layer and this is not possible anymore because there is no airwire. Is there anyone that can help me?
    autodeskguest over 12 years ago
    On 1/12/2013 12:47 a.m., Remko Koornneef wrote:
    You can ROUTE at any time to add more routing after you have used up the
    airwires.
    With the Route tool selected, hold down the CTL key and click where you
    want to start the new routing. The route will be automatically named to
    the trace it attaches to.
    HTH
    Warren
    airwires.
    HTH
    Warren
