EAGLE User Support (English) Installing Eagle 6.5.0 under Debian Wheezy (installation script error)
  • Subscribers 187 subscribers
  • Views 666 views
netizenk
netizenk over 12 years ago
Hello my friends,
I am writing this today in hope that you might be able to help (or point me in the right direction)
I am attempting to install Eagle 6.5.0 under Debian Wheezy, but sadly I get an error that I cannot fathom out.
Initially I use the following
wget ftp://ftp.cadsoft.de/eagle/program/6.5/eagle-lin-6.5.0.run
I then proceed to make it executable
sudo sh eagle-lin-6.5.0.run
However after a few moments it then fails with the following -
eagle-lin-6.5.0.run: 108: eagle-lin-6.5.0.run: /tmp/eagle-setup.17819/eagle-6.5.0/bin/eagle: not found
I have checked the run file and line 108 refers to
"$TMPDIR/eagle-6.5.0/bin/eagle" --setup
Sadly I am a little lost at this point and could certainly use some advice.
Thanks for reading
NetizenK
    autodeskguest over 12 years ago in reply to netizenk
    Am 19.12.2013 19:34, schrieb Keith Beard:
    Thank you for support, sadly I have deleted files and attempted the
    download and re-install just a short while ago, sadly the exact same
    results.
    I will try again a bit later.... I seem to do my best work under the
    power of darkness image image
    http://www.element14.com/community/message/97823
    Are you working with a 64 bit system? If yes  there are probably
    missing some 32bit runtime libraries EAGLE needs.
    I am not very familiar with Debian but I suppose the libstdc++ 32bit
    libraries are not installed. Please check this and then try again.
    ldd for eagle gives the following dependencies:
             linux-gate.so.1 (0xb7714000)
             libXrender.so.1 => /usr/lib/libXrender.so.1 (0xb76ed000)
             libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0xb76e2000)
             libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0xb76d6000)
             libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7648000)
             libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0xb760b000)
             libXext.so.6 => /usr/lib/libXext.so.6 (0xb75f8000)
             libX11.so.6 => /usr/lib/libX11.so.6 (0xb74bd000)
             libdl.so.2 => /lib/libdl.so.2 (0xb74b8000)
             libXi.so.6 => /usr/lib/libXi.so.6 (0xb74a7000)
             libpthread.so.0 => /lib/libpthread.so.0 (0xb748a000)
             librt.so.1 => /lib/librt.so.1 (0xb7480000)
             libssl.so.1.0.0 => /lib/libssl.so.1.0.0 (0xb7421000)
             libcrypto.so.1.0.0 => /lib/libcrypto.so.1.0.0 (0xb7268000)
             libz.so.1 => /lib/libz.so.1 (0xb7251000)
             libstdc+.so.6 => /usr/lib/libstdc+.so.6 (0xb7164000)
             libm.so.6 => /lib/libm.so.6 (0xb711e000)
             libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7100000)
             libc.so.6 => /lib/libc.so.6 (0xb6f4f000)
             /lib/ld-linux.so.2 (0xb7715000)
             libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0xb6f49000)
             libpng16.so.16 => /usr/lib/libpng16.so.16 (0xb6f0d000)
             libexpat.so.1 => /usr/lib/libexpat.so.1 (0xb6ee4000)
             libxcb.so.1 => /usr/lib/libxcb.so.1 (0xb6ec0000)
             libXau.so.6 => /usr/lib/libXau.so.6 (0xb6ebc000)
    Hope this helps.
    Richard Hammerl
    *eagle-lin-6.5.0.run: 108: eagle-lin-6.5.0.run:
    /tmp/eagle-setup.17819/eagle-6.5.0/bin/eagle: not found*
    Hello Keith,
    being pedantic about your initial post, I see that you did not actually
    make it executable, rather you used 'sh' which would run the script part
    of the installer, but not allow the binary part to be executed.
    sudo chmod +x eagle-lin-6.5.0.run*
    should fix this (if it is the problem).
    Cheers,
    bob
  • netizenk
    netizenk over 12 years ago in reply to autodeskguest
    Thank you for support, sadly I have deleted files and attempted the download and re-install just a short while ago, sadly the exact same results.
    I will try again a bit later.... I seem to do my best work under the power of darkness image image
    autodeskguest over 12 years ago in reply to autodeskguest
    On 12/19/2013 11:08 AM, Reece R. Pollack wrote:
    On 12/19/2013 09:33 AM, Keith Beard wrote:
    Hello my friends,
    Hi Keith,
    Sounds like the downloaded file might be corrupted, try downloading the
    file again.
    Best Regards,
    Jorge Garcia
    Hello my friends,
    advice.
    I don't have Debian installed -- I use LinuxMint. Perhaps /tmp is
    mounted "noexec"?
    -Reece
