EAGLE User Support (English) Rotate group of objects about center point?
  • Replies 7 replies
  • Views 3936 views
autodeskguest over 12 years ago
Hi would like to rotate a group of objects 180 degrees about their
combined center. It is too difficult to accurately do this using the
mouse, how can get this done?
Glenn
  • Pedro147
    Pedro147 over 9 years ago in reply to autodeskguest
    Thanks a lot for the ULP Warren. I needed something to rotate a board by 45° in the board editor. Modified it and it works a treat image
    autodeskguest over 12 years ago in reply to autodeskguest
    On 1/22/2014 2:33 AM, warrenbrayshaw wrote:
    On 22/01/2014 4:14 a.m., Glenn Jones wrote:
    Hi Warren, "Is it the centroid of the group's pads" is what i want.
    I expected to be able to rotate the entire group in place so that I
    don't have to try and relocate it afterward.
    Sounds like a feature request now image
    Glenn
    Try the attached ULP
    It rotates the group around the pad/smd centroid.
    I suspect this is not what you want. I feel you are likely after
    'transpose horizontally'
    Warren
    Hi Warren,
    First let me say thank you! for writing that ulp.
    It works great in the board editor. I neglected to mention that I was
    actually trying to rotate the pads in the package library editor. image
    For an enhancement it would be handy for the ulp to take a rotation
    amount as my requirement this time was for 180 (transpose) when it could
    be any amount.
    Glenn
    Glenn
    Warren
    rotate_group_centroid.ulp.zip
    On 1/21/2014 1:59 AM, warrenbrayshaw wrote:
    On 21/01/2014 7:25 p.m., Glenn Jones wrote:
    Hi Warren, thanks for the response. I am having trouble manually finding
    the exact center of the group. Is there anyway to tell Eagle to locate
    the cursor to that point?
    Which center are you after? Is it the centroid of the group's pads, the
    part outlines or all part objects including names and values?
    Eagle cannot do it out of the box but a ULP could be written to do it.
    Can you not rotate the group as I suggested earlier and then just move
    the group as a whole to correct for any misplacement?
    Warren
    Glenn
    Warren
    Glenn
    Hi Glenn
    To rotate elements about a point on the board, I would do it thus:
    Enter into the command line
    Display NONE 21 23;
    <enter>
    Select MARK and click at the spot you call the center
    rotate R180 (c>R0 0)
    <enter>
    The group pivots around the MARK by 180 degrees
    HTH Warren
    Glenn
    Glenn
    Hi Glenn
    Display NONE 21 23;
    HTH Warren
