EAGLE User Support (English) Eagle 5.12 Linux on Ubuntu Saucy 64bit?
  • Views 1335 views
  • Ubuntu
  • saucy
  • 64bit
  • 5.12
  • amd64
amigabill
amigabill over 12 years ago
I used to be able to use Eagle 5.x on my 64bit Linux. I'm now having problems with it.
I suspect that the new way they deal with 32bit compatibility may be an issue. I have libpng installed, but Eagle 5.12 cannot find it.
eagle
eagle: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
ls /usr/lib/libpng*
ls: cannot access /usr/lib/libpng*: No such file or directory
ls -l /usr/lib/x86_64-linux-gnu/libpng*
-rw-r--r-- 1 root root 245538 Aug 22  2013 /usr/lib/x86_64-linux-gnu/libpng12.a
lrwxrwxrwx 1 root root     13 Aug 22  2013 /usr/lib/x86_64-linux-gnu/libpng12.so -> libpng12.so.0
lrwxrwxrwx 1 root root     35 Aug 22  2013 /usr/lib/x86_64-linux-gnu/libpng12.so.0 -> /lib/x86_64-linux-gnu/libpng12.so.0
lrwxrwxrwx 1 root root     10 Aug 22  2013 /usr/lib/x86_64-linux-gnu/libpng.a -> libpng12.a
lrwxrwxrwx 1 root root     11 Aug 22  2013 /usr/lib/x86_64-linux-gnu/libpng.so -> libpng12.so
Since we no longer have ia32 package, how else can we solve this?
Now, I was able to get Eagle 6.5.0 to work. Ubuntu has a package for Eagle 6.4.0, which I installed to get dependencies, then removed, keeping those dependencies, and tried my 6.5.0 install, which did come up. But there are occasions where I want 5.x, not 6.x. And I had previously been able to use both versions of Eagle without problem.
Before installing the Ubuntu package for Eagle 6.4.0, the lack of dependencies gave me a So such File or Directory error, for both 5.12 and 6.5 versions of Eagle. So the dependencies did make a difference for 5.12 as well, but there's still something not right.
I had updated my Kubuntu to Saucy a while back, but have been distracted with various things and have only now tried to load up Eagle since Summer 2013 sometime.
I tried to make a link to pick up the "multi-arch" style of things, but did not work, giving a wrong ELF type error
cd /usr/lib
sudo ln -s  x86_64-linux-gnu/libpng12.so.0 libpng12.so.0
eagle
eagle: error while loading shared libraries: libpng12.so.0: wrong ELF class: ELFCLASS64
So I don't understand how multiarch is supposed to work, or what the difference is between 5.12 and 6.5 about this.
I use Environment modules tool to select which version of Eagle is in my path, which has worked for me for several years like this:
module avail pcb
------------------------------- /opt/Modules/modulefiles -------------------------------
pcb-tools/eagle/5.10.0         pcb-tools/gerbv/2.6.0
pcb-tools/eagle/5.11.0         pcb-tools/kicad/bzr2932-stable
pcb-tools/eagle/5.12.0         pcb-tools/kicad/bzr3044-stable
pcb-tools/eagle/6.5.0          pcb-tools/kicad/bzr3256-stable
module load pcb-tools/eagle/6.5.0
which eagle
/opt/pcb/eagle/6.5.0/bin/eagle
module unload pcb-tools/eagle/6.5.0
which eagle
(nothing found)
module load pcb-tools/eagle/5.12.0
which eagle
/opt/pcb/eagle/5.12.0/bin/eagle
    autodeskguest over 12 years ago in reply to AnalogNotes
    I have had the similar issue:
    http://balubati.atw.hu/blog/index.php?entry=entry111108-115133
    2014-03-24 02:23 keltezéssel, Doug Wellington írta:
    Rob wrote:
    Use a better Linux?
    LOL!  I'm a confirmed RedHat Enterprise/CentOS guy myself, even though
    some would argue that apt is better than yum.  I've found apt to be too
    smart for its own good sometimes...
    My own question is why doesn't Cadsoft just compile a 64 bit version of
    EAGLE...?
    http://www.element14.com/community/message/107117
  • AnalogNotes
    AnalogNotes over 12 years ago in reply to autodeskguest
    Rob wrote:
    Use a better Linux?
    LOL!  I'm a confirmed RedHat Enterprise/CentOS guy myself, even though some would argue that apt is better than yum.  I've found apt to be too smart for its own good sometimes...
    My own question is why doesn't Cadsoft just compile a 64 bit version of EAGLE...?
    problems with it.
    Do you? The right one?
    eagle
    ls /usr/lib/libpng*
    OK, so the answer is no, you don't have libpng for 32-bit applications
    at all.
    This directory is irrelevant - it's the 64-bit libraries for native
    64-bit applications.
    Use a better Linux?
    Or ask on an Ubuntu forum about reinstating libpng12 for 32-bit
    You've done an upgrade in which APT has decided there are no longer any
    users of libpng12 (32-bit) and thus has removed it.
    Yes, that's probably what did it.
    cd /usr/lib
    No, that won't work. There's a reason the 32-bit libraries and 64-bit
    libraries are kept separate - they're NOT THE SAME, nor even compatible.
    The difference is that 6.x doesn't use the libpng12 library any more.
