EAGLE User Support (English) Corrupted project file?
  • Replies 22 replies
  • Views 3340 views
Dear Experts out there, I got this error while opening my project...
Loading C:/SPB_Data/eagle/PFC_Power_Converter_Board_v.1.0/PFC_Power_Converter_Board_v.1.0.sch ...
Warning(s):
line 16553: invalid value '' for attribute 'name' in tag <net>
Error:
line 16575, column 6: invalid/missing attribute 'name' in tag <net>
What can I do? I have tried the backup file but to no avail. image
  • rachaelp
    rachaelp over 10 years ago in reply to sauerwald +1
    Mark Sauerwald wrote on Thu, 07 January 2016 03:51 Do I need to recreate the whole design from scratch, or can I salvage this? Hi Mark, Hopefully Warren's answer above should sort you out but just relating…
    autodeskguest over 10 years ago in reply to rachaelp +1
    Folks, I didn't intend to start a war over which source management system to use! It's more important that you USE one than WHICH one you use. I've used a bunch of them, including SCCS, CMS, CVS, Subversion…
  • clem57
    clem57 over 10 years ago
    Can't open most schematics created before Eagle 6.1   are you trying to load an older version of eagle produced file?
    C
    Former Member over 10 years ago in reply to clem57
    no, I have started to use v7.3 and created a new project. anyway found the root cause as one net have missing net names.
  • sauerwald
    sauerwald over 10 years ago
    I am having the same issue.   In my case it is a design created in Version 7.1, and I get the same errors if I try to open in either Version 7.1 or 7.5   I get similar warnings and errors for both the SCH and BRD files, line numbers are different buth they are both worried about an invalid/missing attribute.
    Warning(s):
    line 1285: invalid value '' for attribute 'name' in tag <signal>
    Error:
    line 1301, column 9: invalid/missing attribute 'name' in tag <signal>
    autodeskguest over 10 years ago in reply to sauerwald
    Warning(s):
    Error:
    this?
    Hi
    You should be able to salvage.
    For the Errors listed
    Open the board file in a text editor
    Go down to line 1301
    There it has detected that the format of the line is unexpected.
    It is expecting it to start like:
    as the name should be made to
    match those contacts on the schematic.
    This should get you going but you will likely have consistency errors
    between the board and schematic so you may have more work to do.
    I would try to get either board or schematic opening by  them selves
    first and then once that works open them both, then fix the
    inconsistency errors to make them consistent. When you do this, work out
    what you want to do to one of the files and close the other before you
    do it.
    HTH
    Warren
  • rachaelp
    this?
    Hi Mark,
    Hopefully Warren's answer above should sort you out but just relating to
    your final comment, it's always a good idea to keep backup's of earlier
    version so if anything get's lost/corrupted you can always go to the last
    backup. Since eagle now uses a text based rather than binary file format
    you can do this nicely and track your changes with a version control
    system. I use Git for all my projects and I check in regularly with a
    description of exactly what I have changed so I can always go back and look
    what I have done over the history of a design which can be really useful on
    a big project with lots of changes. You then also have easy backups to
    another machine or an off-site git server. You simply check in changes and
    then push them to the remote location. Doing this means you'll never have
    to ask the above question as you'll know you can always go back to the last
    known good check in if something bad happens.
    Best Regards,
    Rachael
  • sauerwald
    sauerwald over 10 years ago in reply to rachaelp
    Thank you for your advice Rachel and Warren for the suggestion.   I'll try the text editing suggestions out when I get home tonight - I use Eagle at home, and Altium at work, and there is always a transition period when I jump from one system to the other, but the text editing strategy looks like a good place to explore!   I was dreading having to redo this design from scratch, it is 10 sheets of schematic so it would have been some work!
    At work, we use Perforce for version control and sharing - but I am not as diligent with my projects at home as I am at work.    I should look for a middle of the road solution and GIT looks interesting, I'll have to try that out.
    to try that out.
    At work I have Visual Source (un)Safe inflicted on me but all my home
    projects live in Subversion, at least partly because it's such a doddle
    to administer.
    Just to add a little, prompted by Rachael,s comment.
    Eagle stores backups each time you save so the last of these may work for
    you.
    See the manual that explains the file naming of the saves and automatic
    backups.
    If you had done quite a bit of work since that last save maybe there's a
    bit to much of a difference to use it and hence getting to work with the
    text editor is the way to go.
    What could be of value is, The backup may have exactly what you need to
    repair the broken files so once you locate it, a simple cut and paste will
    get you going and possibly the Schem and Board will be consistent.
    Warren
    I've worked extensively with a number of open-source source management
    tools, including Subversion and GIT. For the home user I recommend
    Subversion over GIT.
    GIT is extremely powerful. It's designed explicitly to support massively
    parallel development with very powerful branching and merging
    capabilities. If you know how to use it it's great. However, it's also
    cryptic, hard to learn for many people, and a real pain when it breaks.
    Subversion is far more limited. It depends on having a central
    repository for your projects. That's a bad thing if you're trying to
    manage multiple parallel development efforts, but most basic users find
    it easier to learn and use.
    I spend much of my professional life developing Linux kernel code. That
    means I have a fair bit of experience using GIT, and would consider
    myself a fairly competent user. I also use GIT to manage my personal
    projects, mainly because I was using GIT so much I found I was
    forgetting how to do things with Subversion.
    One of the keys to successful use of a source management system is
    making sure the important stuff gets committed, and none of the garbage
    gets committed. For example, Eagle creates "backup" files by renaming
    the current version of its files to the "backup" name before creating
    the new version. None of these "backup" files should ever be committed
    to your source management system because they're basically useless
    garbage you'll never want to use. If you find yourself thinking you
    might want to go back to one of those older versions, that a sign you're
    not committing your work often enough!
    One of the ways to make this easier is to have the source management
    system ignore the files you don't want to commit. To have GIT ignore the
    "garbage" files Eagle creates, create a file called ".gitignore" in the
    top directory of your project with the content between the lines of hashes:
    .eaglerc
    .cache/
    .fontconfig/
    .config/
    *.b#[0-9#]
    *.l#[0-9#]
    *.s#[0-9#]
    *.pro
    The file name may be a bit different on Windows or Mac systems. I don't
    use GIT on these systems.
    You can do something similar with Subversion by setting the "svn:ignore"
    property, or set the global-ignores option in its config.
    to try that out.
    http://www.element14.com/community/message/170956
  • sauerwald
    sauerwald over 10 years ago in reply to autodeskguest
    Thank you Warren
    I was able to fix the files, and get my schematic and board layout back into sync.
