EAGLE User Support (English) .brd & .sch files unlinked - Trying to link them back together
  • Subscribers 178 subscribers
  • Views 1229 views
Hello everybody
I've finished a design yesterday evening. When I then tried to reopen the
design to do an alteration, I got the message that the .brd file doesn't
exist. I then opened the .brd file and when I click on switch to schematic,
I get a message that the Board and schematic are not consistent. When I
click OK, it opens a new schematic file that is blank. (Two different
control panel windows open)
I would like to link the two files together again so that I can make the
alterations since redesigning the PCB will be a lot of effort. Is this
possible or have I caused myself a lot of rework? Thank you in advance.
Dirk
    Hello Everybody
    I've resolved this issue by just creating a new .sch file from the existing
    brd file. I then opened up the existing .sch file and copied all the
    content over to the new .sch file. Saved everything and it is now linked
    together again.
    Dirka wrote on Thu, 01 May 2014 05:21
    Hello everybody
    the design to do an alteration, I got the message that the .brd file
    doesn't exist. I then opened the .brd file and when I click on switch to
    schematic, I get a message that the Board and schematic are not
    consistent. When I click OK, it opens a new schematic file that is blank.
    (Two different control panel windows open)
    the alterations since redesigning the PCB will be a lot of effort. Is
    this possible or have I caused myself a lot of rework? Thank you in
    advance.
    Dirk
    Glad you got it working Dirk.  I don't see that inconsistency happen very
    often any more.  There was a bug in earlier versions where it happened
    quite often during a library update but I think that has been resolved.
    In any case, the generic way to fix this is to look at the ERC and see what
    is different between the two, manually add what is missing, and then redo
    the ERC.  It can be as simple as adding or correcting an attribute or net
    name or can be as complicated as having to add a whole sub-circuit.
    But as you say, if you already have a large part of the PCB layout done,
    you don't want to have to redo that.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
    autodeskguest over 11 years ago in reply to autodeskguest
    Thank you James
    First time that this has happened with me now. Luckily it is resolved now.
