EAGLE User Support (English) Device unlinked from library, how to detect?
  • Replies 10 replies
  • Subscribers 177 subscribers
  • Views 1876 views
This problem is very old. Sometimes I upgrade my libraries and give devices
a new name. Sometimes I delete buggy devices.
When I from a project use the "library->update all" funcion, I get no
notifications of the placed components that doesn't exist in library
anymore. That is scary.
When I (from the v6 contect menu) choose "open device" I get the error:
"Package variant 'xxx' of deviceset yyyy does not exist in current library
. Please adjust the library path or export the drawing
libraries first!"
I do not want to do this for every part present on my brd/sch. It is
possible to write an ULP to find them, but I think it should be part of the
library update function.
I would very much like to know what devices are no longer linked to the
library, cause I want them to reflect the new stuff. If I have to manually
replace them, thats fine. The worst thing that can happen is the device
being old (maybe even buggy) and not supported by my libs anymore.
Maybe there is already a solution to identify these obsolete library parts?
PS:How to confirm? Just temorarily rename a device you know exist in a
project, then do library update. The project won't know its gone from the
library.
    autodeskguest over 11 years ago in reply to autodeskguest +1
    "James Morrison" skrev i nyhetsmeldingen: lkbtsa$4q0$1@cheetah.cadsoft.de ... What is scary ? How is that all not considered very scary? Thanks for the support. We agree on the severity of this issue,…
    devices a new name. Sometimes I delete buggy devices.
    This would be an interesting point to discuss. In EAGLE, once a part is
    brought into a design it is completely independent of its parent
    library. The only thing linking them at that point is basically the
    library name.
    What is scary about this behaviour? No data can be lost since as long as
    you have the part in a design you can always recover part into a library.
    library <library filename>. Please adjust the library path or export the
    drawing libraries first!"
    the library update function.
    It's important to remember that Update all checks only libraries that
    are in the paths specified in the Control Panel -> Options ->
    Directories. If you're library is stored outside of those directories
    you'll get the same error.
    hth,
    Jorge Garcia
    Jorge Garcia wrote on Tue, 06 May 2014 16:01
    give
    no
    library
    library name.
    as
    library.
    error:
    export the
    is
    part of
    Jorge,
    What is scary ?  How is that all not considered very scary?  For anyone who
    had designed boards this is a nightmare because you lose control over being
    able to deterministically understand what is happening to your design
    during a library update.
    I've posted about this many times.  The library update needs to provide a
    full report.  That should include at least:
    what parts were found and identical (and therefore didn't change)
    what parts were not found in the library
    what source libraries were not found
    what parts were updated and what the changes were
    I've had boards come back not functional because a device name was changed
    in the library after it was added to the schematic.  After that, the
    library update will quietly ignore that part but won't tell you about.  So
    you can make changes to the device in the library (the master copy) but it
    won't make it into your current design.  So the board comes back wrong if
    you don't catch it.
    Now I should have checked and caught that.  In that case a lot of things
    had changed and I had checked all the other library changes but forgot to
    check that one.  But isn't the tool supposed to be help in exactly these
    cases where the task can be automated.
    So please CadSoft, don't blow this request off.  This is a real issue that
    happens in the real world and it would be so easy to address.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
    Thanks for the support. We agree on the severity of this issue, but I dont
    have same requirement for documentation, especially if there is no change
    (but it would be a nice option).
    Mainly I need to know wich ones are not present in a used library anymore.
    It could show the replace dialogue if one is missing (like if the
    package/symbol has changed), with a "continue(dont update this device)"
    button.
    I guess undo will work, so the need for an action list for every device
    before executing the changes is not something I miss, but would be nice.
    Am 07.05.2014 10:11, schrieb Morten Leikvoll:
    anymore.
    This one is already in EAGLE since >= 6.5.2, from UPDATE_en.txt:
    "Library update: Information to the user about devicesets that are used
    in schematic but can't be found in the corresponding update library."
    James is absolutely right when requesting a full report. I'm missing
    that as well. At least, they took the very first step. Hopefully we get
    V6.6 some day...
    Rene
    "René König"  skrev i nyhetsmeldingen: lkcrgi$kpj$1@cheetah.cadsoft.de ...
    anymore.
    Cool! I guess I have to update to 6.5.2 beta. Thanks image
    "Morten Leikvoll"  skrev i nyhetsmeldingen: lkcush$7ce$1@cheetah.cadsoft.de
    anymore.
    Just tried it but something looks bugged.
    I got a mismatch on a FPGA:
    quote
    Following devicesets are used in schematic but have not been found in the
    corresponding update library:
    Altera.lbr 4SGX180_F1152
    If this is not intended, adjust the library paths or library deviceset names
    and update again.
    unquote
    I tried replacing it, and even change package, but I still get same mismatch
    after update all.
    Also tried the same after renaming the altera.lbr to altera2.lbr. Still
    mismatch.
    Also tried dropping libs and using them again.. Still mismatch..
    The Altera.lbr contains the device 4SGX180_F1152 with package name
    4SGX_F1152, and a pile of symbols with different names wich I believe are
    unchanged.
    Any ideas?
    For the interested, Walter found the cause of this issue.
    At "update all", v6.5.4 Beta scans the entire library paths for the library
    name (even those not in use). In my case it saw the same library name in a
    different folder, and compared it with that.
    I suspect this will be fixed in a future version.
    library name (even those not in use). In my case it saw the same library
    name in a different folder, and compared it with that.
    This has been mentioned before, by me, only 4 weeks ago.
    Same part name in another library folder on another path in your
    directory options and you get the update from the first one that matches.
    The libraries are searched in the order they are specified in the
    directories settings.
    What should be changed for an 'Update all' is the matching should
    continue to the end of all libraries and the user advised if there is a
    second match and not perform update until you advise which one you want.
    Of course, you should manage your libraries so there are no duplicates
    of library name and part but novices will often so this when they are
    unaware of the trap.
    Warren
    "warrenbrayshaw"  skrev i nyhetsmeldingen: lki0aa$lun$1@cheetah.cadsoft.de
    Same part name in another library folder on another path in your directory
    Sorry for not catching it.
    What should be changed for an 'Update all' is the matching should continue
    to the end of all libraries and the user advised if there is a second match
    Of course, you should manage your libraries so there are no duplicates of
    library name and part but novices will often so this when they are unaware
    of the trap.
    My suggestion is simply to only scan libraries in use and report if several
    of the projects devices come from a library that is not in use.
    Your suggestion seems to open the door for a lot more bugs, and require a
    lot more work, so maybe for a future version?
    [quote title=Morten Leikvoll wrote on Fri, 09 May 2014
    03:43]"warrenbrayshaw"  skrev i nyhetsmeldingen:
    lki0aa$lun$mailto:1@cheetah.cadsoft.de
    Isn't that how it is supposed to work?  The directories in the Control Path
    -> Directories settings are in order of priority from left to right.  As
    soon as EAGLE finds a file that matches it stops looking.  This is true for
    running scripts and ULP's as well as updating.
    I agree, you should generally not have 2 libraries with the same name, but
    if you do that is what the priority takes care of.  However, if you don't
    know then I guess that could cause confusion.
    If there was a full report at least you'd see what was updated and where it
    came from.  Then it wouldn't be hidden at least.
    continue
    match
    of
    unaware
    >of the trap.
    several
    a
    I don't think the libraries "in use" should be the qualification for what
    is searched.  The "use" command really only tells EAGLE which libraries to
    consider when adding parts.  But I could easily (and often do) "use" a
    library to add a couple parts and then remove it from "use" because I know
    I don't want any more parts from that library.  And the more libraries are
    in use, the longer it takes for the Add Device dialog to appear.  So I
    would often have devices in my designs that are not part of libraries that
    are in use at the time of the update.
    I think EAGLE should, for each device in the design, look for that device
    in all of the libraries that can be found in the EAGLE Library Directories
    (as specified in Control Panel).  If it finds a match for device name and
    library (that matches the library reference in the device itself) then it
    goes ahead and tries to update.  Anything else should not be updated.
    And of course a full report should be created of what happened during the
    update for EVERY device in the design.  The idea is that the designer
    should have full knowledge of exactly what happened during the update and
    exact HOW each device changed or why it did not change.
    There are two things that the "update all" command needs to look for:
    device and library (that is referenced by the device).  Only if it finds
    both should it replace the part.  If it actually looking into other
    libraries that is not correct and should be fixed immediately.
    CadSoft, please think like a designer about this.  I have designs with
    close to 1000 parts and when I do "update all" there is no possible way I
    can ensure currently that one specific change I made was included in the
    update.  And as I stated, even as a veteran designer and EAGLE user, I
    still had a board come back non-functional about 6 months ago because of
    this issue.
    James.
