EAGLE User Support (English) How to import Altium files into Eagle?
  • Views 7876 views
Can Altium files be imported into Eagle Pro?
(I am referring to Altium schematics, PCB files and library files)
Also, is the import process perfect, and no discrepancies are produced whatsoever?, the imported Altium files , when converted, will not even need checking over?
    autodeskguest over 11 years ago in reply to e14 Contributor
    On 8/19/2014 2:34 PM, Rafaek Send wrote:
    Hi, I am also having trouble with this. I have received an exported
    ASCII .sch file from a colleague who works in Altium, but I am getting
    the error that says "Wrong file signature: DProtel".
    What instructions can I give him so that he exports something Eagle will
    work with?
    Rafael
    http://www.element14.com/community/message/124136
    Hi Rafael,
    Here's what I've got:
    Board:
    SAVED_COPY_AS
    SAVED_AS_TYPE
    EXPORT_PCAD_ASCII
    Schematic:
    For the schematic I don't have a complete procedure,
    here you basically have to make sure that the part information
    is included as part of the pcad ascii file and not a separate file.
    PROJECT_SAVE as PCAD ASCCII
    The option is called: Export P-CAD V16 ASCII Schematic file
    hth,
    Jorge Garcia
    e14 Contributor over 11 years ago in reply to autodeskguest
    Hi, I am also having trouble with this. I have received an exported ASCII .sch file from a colleague who works in Altium, but I am getting the error that says "Wrong file signature: DProtel".
    What instructions can I give him so that he exports something Eagle will work with?
    Rafael
    autodeskguest over 12 years ago
    On 5/6/2014 12:52 PM, grigson prendergast wrote:
    need checking over?
    Hi Grigson,
    They can be imported, you have to export the schematic and PCB files as
    ACCEL-ASCII files. EAGLE can then import those files, at this point
    Libraries are not supported.
    The import works pretty well, however it's not perfect and there maybe
    some need to clean up the design after the fact.
    Best Regards,
    Jorge Garcia
