EAGLE User Support (English) Is it possible to convert polyline to polygon
  • Subscribers 178 subscribers
  • Views 1416 views
  • lines
  • convert
  • polyline
  • polygon
lrc
lrc over 11 years ago
Hi Jorge,
I used lines to draw a polygon shape previously.  The lines are all connected at each of their ends,  in other words the lines form a continuous closed shape.
Is there any way in Eagle to convert this "polyline" shape to a true polygon so that it may be filled with copper?
Thanks!
Lance Carlson
    not out of the box, but:
    If you are using a recent version of eagle (xml file format is the key
    here) I'd consider editing the board file manually (at least for a
    one-time job).
    To get a feel for what needs to be edited I'd create a new board file
    with both a polyline and a polygon with similar outline.
    In case you plan to do such conversions more often, I'd look out for
    an ULP to do it (or write one myself).
    Lorenz
    Former Member over 10 years ago in reply to autodeskguest
    Hi Lorenz,
    I'm dealing with the same problem... I had imported some shapes from dxf file and I need to cover that area with copper.
    Unfortunately the rastnets command doesn't work because it is not able to identify a closed shape.
    Could you kindly send the ULP routine for the conversion of wires in polygons? Or give me more information how you had solve the problem?
    Thanks.
    Alessandro
