EAGLE User Support (English) import asc file
  • Subscribers 178 subscribers
  • Views 1133 views
import asc file
I use the publication 6.5 Pro
Has become control in the correct operation of import of asc file
If yes because I receive this message of error
    No one does not know which problem it exists ?
    It would be supposed you clarify that they are limited effectiveness the import of asc file
    Nice support from the cadsoft
    screen shot didn't make it to the newsgroup
    you could just have mentioned that you try to use import-accel.ulp and
    that the error it generates is "Wrong file signature".
    From a quick look into the ulp I'd guess that the file you try to
    import has the wrong file format.
    If you need more help you will need to provide more detailed
    informations about your situation.
    Lorenz
    Former Member over 11 years ago in reply to autodeskguest
    What is (import-accel.ulp) I do not know
    I do not use no one (import-accel.ulp) I make import of file asc From the eagle (File/import/P-cad/Altium/Protel..)
    picture does not exist in file PCB that I made export in asc
    What more details to I give, except the error message?. I do not understand
    Poll
    Former Member over 11 years ago in reply to Former Member
    Who the aim of operation of support forum ?
    When does not exist official support from the cadsoft engineers
    This is who easy question in order to you give me answer yes or no ?
    I thank for the direct support that I did not have in my problem
    poll western
    autodeskguest over 11 years ago in reply to Former Member
    Email directly to Cadsoft Support
    http://www.cadsoftusa.com/services/support/?language=en
