EAGLE User Support (English) PCB guard ring
  • Subscribers 183 subscribers
  • Views 1551 views
  • guard
  • pcb
PCB guard ring
bradabrown
bradabrown over 11 years ago
Beginner with Eagle but not with PCB design.
I need pointers on implementing guarding (e.g., guard rings) using Eagle.
My current project is just two layer.
I have one signal entering non-inverting pin of an op amp I'd like to guard and drive the guard with op amp buffer output.
Thanks for any assistance!
Brad B.
Update 2014-07-07
Thanks for the tip on board coatings.
I worked on a picoammeter in the past using green board but can't recall how I worked around this problem.
To answer my own post:
I defined a new net class "guard" (8 mil) and used a dashed style to lay down the net.
Biggest problem is clearance errors if wrapping an input pin on an SO08 op amp package.
  • D_Hersey
    D_Hersey over 11 years ago +1
    I can't help ya, but I got a tip that you are probably well aware of: If you are using green or blue board you probably need to scrape off the top coating of the board around the inputs with a probe in…
    autodeskguest over 11 years ago +1
    "Brad Brown" skrev i nyhetsmeldingen: 1199504333.91404672833226.JavaMail.jive@flcspu-csapp-01.premierfarnell.com ... I need pointers on implementing guarding (e.g., guard rings) using Eagle. 3 suggestions…
  • D_Hersey
    Another tip, and again you may already be hip to this one as well, you can avoid having to acquire a freakishly high valued feedback resistor if you use a three-resistor attenuator instead.
  • D_Hersey
    I can't help ya, but I got a tip that you are probably well aware of:  If you are using green or blue board you probably need to scrape off the top coating of the board around the inputs with a probe in the context of a high-Z circuit.  It is a little bit conductive and can screw you up.
    Eagle.
    3 suggestions:
    1.You can use WIRE and draw any ring using wire, then rename the wire to the
    signal name to attach it (the wire will become a track)
    2.You can use ROUTE and CTRL-leftclick to start routing a ring from anywhere
    on an existing track.
    3. You can define a POLYGON around the guarded net, rename it to the
    guarding signal name, and fill it with ratsnest.
    Good luck image
  • D_Hersey
