EAGLE User Support (English) New layer 99 in eagle?
  • Replies 9 replies
  • Subscribers 177 subscribers
  • Views 1210 views
Devices in the diode.lbr contain a new layer 99 "spice order" in devices
1N4004, 1N4148, 1N4446...
I haven't checked other libraries...
Is this correct?
This happens in eagle 6.6.0 and also in 6.91.2 beta (win8.1)
Joern Paschedag
    Am 08.07.2014 13:07, schrieb Joern Paschedag:
    Is this correct?
    In EAGLE V6, we started into a cooperation with Linear Technology.
    LT offers a free spice simulator, LTspiceIV. For exchanging data we
    require simualtion information for the libraries of LTSpice.
    Each PIN in EAGLE has to be assigned to a number, the Spice order.
    This was done with the help of a new layer. It was impossible to
    manage this with attributes. So we decided to introduce a layer
    "99, Spice Order" where the required information is placed as a
    text directly at the coordinate of the PIN in the symbol.
    So a ULP compares the coordinates of the PIN with the coordinates
    of the text and recognizes the assignment.
    Layer 99 may be switched off at any time in the eagle.scr with
    DISPLAY NONE 91 21 94 95 96 97 98;
    Richard Hammerl
    autodeskguest over 11 years ago in reply to autodeskguest
    Am 24.07.2014 um 14:44 schrieb Richard Hammerl:
    Is this correct?
    Thanks for the information but layer99 is not mentioned in eagle help.
    Joern Paschedag
    Joern Paschedag wrote on Thu, 24 July 2014 09:43
    devices
    Is this correct?
    Technology.
    we
    order.
    Yeh, I don't remember that ever being mentioned.  I haven't used the
    LTSpice interface much yet so I haven't run into it.  But, that should have
    been announced in a very obvious way since users could have been using
    layer 99 for something on their own.  Whenever a new layer is commandeered
    there should be big, obvious release notes and lots of noise about it
    because you could be breaking my current library.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
    Am 25.07.2014 um 01:28 schrieb James Morrison:
    devices
      Is this correct?
    Technology.
    we
    order.
    Yeah, but it was always said not to use private layers below 100.
    James.
    I see it the same way.
    I thought it was an error because i didn't find that layer in rcl.lbr or
    transistor.lbr which are imho also supposed to be used in spice. Also it
    was not mentioned in the help, so I removed the layer.
    Joern Paschedag
    If it had been documented as "reserved for future use" or something like
    that (allocate some layers for special CADSOFT use and document it), then
    they do indeed need to announce they have added a layer.  Nothing in the
    documentation (that I have read) says anything about reserved layers, so
    others can use them then it breaks their libraries when Cadsoft decides to
    use that layer and it should be in the release notes in BOLD so others are
    aware of it.  Stuff happens, but when you grab a layer that others may be
    using since they were told they could use it, it needs to be clearly
    identified to the user in the release notes and even a special notice in
    the "What's new in this version".
    mikey
    Drat - coffee has not kicked in ... should be "If it has NOT been
    documented ... "
    mikey
    From page 234 of the Eagle 4.1 user manual :
    "If you want to create your own layers, please use layer numbers above 100."
    They warned you. If you ignored them, it's not their fault.
    Rob Pearce wrote on Fri, 25 July 2014 12:11
    100."
    Whether it's there or not, I would expect that any new layers that are
    created as a default should be listed in the release notes.
    For instance, there are special layers in the 50's that aren't used but
    work as auto-mirrored pairs (like tPlace and bPlace).  I use one of these
    pairs since there is nothing like it above layer 100.
    But in general, if something is done that could break users' libraries than
    that should be listed in the release notes 100% of the time, whether there
    is a warning in the manual or not.
    Cheers,
    James.
    100."
    I had missed that - so the warning was there although it would still be
    good practice to announce it in the release notes that they were going to
    now be using that layer.  Like the old (this will date me !!) S-100 bus -
    there were several undefined signals that a number of different venders
    grabbed and used which then made some cards not play well on the bus.
    mikey
