EAGLE User Support (English) Eagle 6.6 General Layout Questions
  • Views 623 views
autodeskguest over 12 years ago
I'm beginning a design in Eagle Layout and I have a few questions regarding
setup and use of the tool.  I've read the documentation and searched the
forums and have been unable to find an answer, so I thought I'd post.
Here are my questions:
1) Does Layout offer active DRC (automatic rules checking as I'm doing
layout)?
2) Does Layout automatically generate a Test Fixture Outline and
Manufacture Outline when I lay down a board outline?
3) Is it possible lock down nets from changes?
Thanks!
Matt
    An email to Cadsoft helped me get an answer to my question:
    Quote:
    Another question, is it possible to set up different net width/spacing
    per layer using classes?
    For example, if you have a differential trace that needs to route from
    the top of the board (width/spacing 5mil/5mil) to an inner layer
    (4mil/4mil), is there a way to use classes to make this happen?
    Unfortunately, EAGLE's current implementation doesn't allow the
    Netclass
    settings to be set on a per layer basis. My recommendation would be to
    set the width to the minimum value necessary and then increase it
    manually where necessary.
    Kind of figured that was the case, but it's good to know image
    Another question, is it possible to set up different net width/spacing per
    For example, if you have a differential trace that needs to route from the
    top of the board (width/spacing 5mil/5mil) to an inner layer (4mil/4mil),
    Thanks!
    Matt
    Thanks Doug, I appreciate the tips and thoughts.  I'll be putting them to
    good use shortly image
    Matt
    layout)?
    No.  I have "drc;" assigned to a function key and I use it after I've run
    any trace that I think is close to some other object.
    FWIW, I have the following lines in my eagle.scr:
    Assign F3 'ratsnest;';
    Assign F4 'rip @;';
    Assign F5 'drc;';
    As I route my board, I run through the sequence F3, F4, F5 to check my
    progress...
    I'm not really sure what that means, but I don't think so.
    I think you can only lock components, not nets...
