EAGLE User Support (English) How to change libraries after routing
  • Replies 7 replies
  • Subscribers 179 subscribers
  • Views 3533 views
I have a design that is completely routed (by hand).  Now I want to
change the look of a symbol used in the schematic.  But I don't want
to disturb any of the existing routing, so I can't delete the part and
add in a revised version of it.  I could edit the library and update.
That would do it.  But the library I got the part from is an
Eagle-supplied library, and I don't want to get into the maintenance
headache of tracking changes to Eagle libraries.  I would much rather
make a duplicate of the part in a custom library of my own, and then
have the part reference my custom library for updating instead of the
Eagle library.  But I don't know how to do that without disturbing the
routing to the part on the PCB.  It is only the schematic that should
be affected.  Is there any way out of this short of editing the Eagle
library this part came from?  I am considering editing the raw XML of
the schematic, finding the library reference, and changing it, but is
that safe?  I mean, what if my library version was accidentally
different in the package too?  What would Eagle do when updating from
a library where the package is inconsistent with the connections in
the PCB?
Robert Scott
Hopkins, MN
    Well, one fairly obvious (and widely recommended) approach is...
    Make a copy of (all of) the Eagle libraries. Put them somewhere
    editable, either in your user area (if you're a one-man-band) or a
    shared project area (if you're part of a team).
    Now edit those libraries as you like.
    Change the directory settings in Eagle to pick up your customised
    libraries before (or instead of) the distribution copies.
    Now you can update your design as if you'd edited the Eagle library but
    without actually doing so. The design stores only the name of the
    library, not the full path.
  • kikoun
    kikoun over 11 years ago
    It's possible to change your symbol without risk and it's quite easy.
    • Start to create a new library, (or open one of your own library). Usually I name it in a way that It could not be mistaken with Eagle's ones, and I store it in an other directory.
    • Then, while your library is open, search in the control panel the device you want to modify. Use a right-click on this device, and select copy to library. This will copy the component into your library (symbol+device+package(s)).
    • You can edit your device and change the symbol, rename it etc...
    • You save your library.
    • You open your schematic (and board) if they don't, and you use the replace tool, to replace the device (from original library) with the device of your new library.
    • In that way you keep the eagle's librarys clean, and you limit the risk, since you just edit an 'already good' device.
    Be careful:
    If you have changed the symbol, but not the names of the pins of the symbol, Eagle will adapt the new symbol, and there will be no change in you board. In the schematic you may re-arrange your wire, because it could look messy (but there will no mix-up in the net list) .
    If you changed the pin names of your symbol, Eagle will try to retrieve the pin by their location. So If you want to change the pin names and their position, the best way would be to it in 2 separate steps, first just renames pin, replace your device with the new version. Then edit again you new library, change the symbol, but not the pin names. Then in you project, proceed a library update.
    If Eagle can not replace with the new symbol without risk of mix-up, Eagle will display a warning or error.
    Good luck.
    Quote:
    But the library I got the part from is an Eagle-supplied library,
    There's the real problem.  Some mistakes can't be fixed after the fact.
    This is one of them.
    Next time think of this before painting yourself into a corner.  The advice
    not to use the Eagle libraries directly is given here often, and should be
    obvious from a little thought anyway.
    That all said, changing one part is not likely to rip up a lot of the
    routing.  If I remeber right, the ripup will only go as far as the next
    part or net junction.
    autodeskguest over 11 years ago in reply to kikoun
    On Tue, 29 Jul 2014 18:06:30 GMT, Guillaume barrey
    <noreply-198664@element14.com> wrote:
    You open your schematic... and you use the
    device of you new library.
    How studid of me.  I never noticed that tool before.  Now that I know
    that it exists, it is the perfect solution to my question.  Thanks.
    Robert Scott
    Hopkins, MN
  • kikoun
    kikoun over 11 years ago in reply to autodeskguest
    if we simply replace with the device of the new library and If only the symbol is changed, there will be no ripup at all. But if a wire is no longer connected to the same net, the ripup stop at first junction or part.
  • dukepro
    dukepro over 11 years ago in reply to autodeskguest
    Robert,
    It's not as bad as Olin infers.  There's a way to do this without
    disturbing your layout.
    Try this:
    I couldn't find where Eagle keeps the path to the library stored in the
    schematic, but it does keep the name of the library.  Thus, this stands
    a good chance of working.  You could copy the eagle library in question
    to your own personal lbr directory WITHOUT changing the name.  Make sure
    your personal directory occurs before the eagle directory in the library
    directory path.  Drop the eagle library from use, and use yours
    instead.  Then modify the symbol, save it, and do a library update.
    I've done this with the RCL library (and others) with success across
    updates and upgrades.
    If that doesn't work, try this:
    Open your personal library and copy the DEVICE from the eagle library to
    yours.  Modify the symbol as needed and save it.  Add this personal
    library to your USE list.  Then replace the device on your schematic
    with the device in your personal library.
    Neither one of these methods should change the board layout, provided of
    course, that the package is identical.  No rip-up and reroute should be
    required.  That said, do a ratsnest to check for air wires and drc just
    to be sure.
    HTH,
        - Chuck
    autodeskguest over 11 years ago in reply to dukepro
    EAGLE stores everything in the board and schematic files.  I'd suggest
    using the exp-lbrs.ulp to extract the libraries back out from your design
    into a local directory, then make your changes and use the "update" command
    to pull them back in...
