EAGLE User Support (English) New storage location
  • Replies 9 replies
  • Subscribers 179 subscribers
  • Views 2210 views
e14candies
e14candies over 11 years ago
I've been using Eagle for some time and completed several projects, no
problem.
Apparently these are all stored in the "same"
c:/users/documents/eagle/specificfolder.... location, each with its own
folder.
For this newest project, I want a totally different path, such as
c:/sam/was/here/project....
How do you select this?  I don't want to change my old projects in any way
or how they are accessed. A different upcoming project will be
c:/bill/was/there/project....
Basically, how can you select EXACTLY where each project folder is stored,
with its own independent path?...it seems like Eagle forces you to let it
choose. (Up till now I went along with its automatic guidance system).
This rather gut-wrenching experience has me starting to drink deionized
water again.
    stored,
    The way I would do it is, from the control panel, go to the Options menu
    and choose "Directories..." and add the new directory to the front of the
    "Projects" path.  Then your new project will be created in that directory.
    You can always drag and drop the projects to a different directory if you
    want...
  • e14candies
    Why can't you just do "save as" and pick your desired project location?  Or
    can you?
    Having to edit a directory path seems like rather poor planning.
    autodeskguest over 11 years ago in reply to e14candies
    can you?
    Hello Hoyt,
    I hope you're doing well. Usually EAGLE expects users to organize
    everything in one major directory which you can organize however you
    wish. My recommendation would be to select such a directory and then
    under that directory create the /sam/... and /bill/... directories as
    necessary.
    hth,
    Jorge Garcia
    autodeskguest over 11 years ago in reply to autodeskguest
    can you?
    Hello Hoyt,
    ...and this is completely crap right from the start.
    It is, and has always been, absolutely boring and senseless to put the
    project files in a central directory resp. structure. The normal way of
    organising projects in a company is to keep everything belonging to a
    project in a well structured scheme, and this includes many other
    documents and files as well - with the EAGLE files being only a small
    part of the files belonging to the hardware design part of the project.
    The only "right way" would be to allow us to us project files *wherever
    we want* (and also named as we like).
    Just have a look at all those IDEs for software development to get a clue...
    The wish/request for ambiguously named and located project files is
    decades old, but still ignored by CadSoft - though it would be very easy
    to implement.
    (For central files like libraries, scripts, ULPs and design rules, EAGLE
    must of course use central directories - but these must reside in
    AppData, not the program directory...)
    Tilmann
    "Tilmann Reh"  skrev i nyhetsmeldingen: lsuqgp$rp6$1@cheetah.cadsoft.de ...
    Agree, this is ancient thinking..
    Careful here. I think some libs, scripts and ulp's also need some degree of
    maintainance and project control. You may want to keep your old lib
    definitions for old projects, and even diff them. I've kind of gotten used
    to make local scr/lib/ulp and even cam folder for every project I do. The
    original libs are just used to copy from, when needed. This does make it
    necessary to add path to the options-directories, so I think there is room
    for improvements.
    I do not really feel its time to suggest additions to Eagle, cause it has
    quite a few slightly annoying old quirks (and even some new since v6) that
    needs to be fixed first, but a version control with diff tools should be on
    the list somewhere, maybe on v9..
  • anweid
    anweid over 11 years ago
    Am 18.08.2014 00:57, schrieb Hoyt:
    What people do here is the following:
      1. If it is not already installed that way, make your OS react to
         double-clicks on any SCH or BRD file by opening EAGLE with the
         clicked file. At least under Windows, that's easily possible.
      2. Do NOT open EAGLE and THEN try to access the folder, but look
         at that folder with your favourite file manager and THEN
         double-click on the desired file, so EAGLE opens up appropriately.
      3. This has the additional advantage (or disadvantage, depending on
         your needs) that every double-clicked design opens a NEW instance
         of EAGLE, so you can look at designs side-by-side.
    Andreas Weidner
    I don't think this is a good idea... You end up with zillions of
    different libraries, maybe of similar names, with true and only apparent
    duplicates of parts - you really can't manage that reliably.
    The original libs are just used to copy from, when needed. This does
    make it necessary to add path to the options-directories, so I think
    there is room for improvements.
    The "original" libraries are so bad that they don't even serve this
    purpose. IMHO, it's better to use only self-defined libraries.
    Sadly, there are so many long-standing issues that were never addressed
    (or even acknowledged), and that could have been fixed rather easily,
    that I don't think they are really listening to us. image
    Tilmann
    "Tilmann Reh"  skrev i nyhetsmeldingen: lt095p$740$1@cheetah.cadsoft.de ...
    of
    used
    Imo, a proper management tool has no problems with that. It would show the
    different version parts in a list - by date - and then you could ask to see
    them and hilite the differences. Then it would ask you to overwrite the
    latest to all the other locations.
    Oh, you are right there. I dont trust them, but sometimes I import from
    them, check and rework them. I can probably count the times Ive done that on
    my two hands.
    that
    on
    They did listen to us on the licensing image But maybe it was all the noise
    they listened to and not what we said..
    Maybe we should ask for a voteable todo list image
    ...or they realized that most of the voices said "I definitely won't buy
    V7". Trying to sell a product that noone wants to buy is hard.
    Obviously, all those long-standing issues didn't have (enough) influence
    on the cash side.
    We already did - this is one more long-standing issue... :-\
    (And of course one needs to take care - many insane wishes would
    probably flood the list and eventually even get more votes than the
    really necessary improvements. Just have a look at the kind of questions
    coming from element14 to get in impression...)
    Tilmann
