I think, there should be a option to set, when VIA on some layer is not
connected to anything, its diameter on that layer is automatically set to
drills size, that mean without ring around hole.
When you route BGA you have to put a lot of VIAs under it, so inner layers,
where is ground or power plane, looks like cheese.
Currently I use some workaround, but it is annoying and not 100% what I
need.
PGW
