EAGLE User Support (English) How to delete a text in EAGLE PCB
  • Views 3152 views
  • delete
  • text
Hello friends, I wrote a text in Eagle PCB (board) and I can't delete! I've tried everything. Anyone can help me?
  • volthaus
    volthaus over 11 years ago in reply to e14 Contributor
    Thank you Tarang Shah. Your suggestion worked perfectly. I put the version number onto the wrong layer (top) and was having a little trouble taking it back off. It's gone now.
    Before playing with various layer settings, I suggest click on the delete button and then the + sign which will be present on any one corner of the text block. It is very easy to miss the small plus sign. You can see it in the picture below. Also note that the plus may be on another corner(depending on how you placed the text originally)
    Hope this works!
    autodeskguest over 12 years ago
    Jose Alvaro wrote on Mon, 13 October 2014 09:57
    http://www.element14.com/community/message/128399
    As everything did not work you should something else.
    You have not said which layer the text is on so that is the first thing to
    establish.
    Turn of the displayed layers one at a time until the text disappears. You
    now know if the text is on a layer. Text should have a origin associated
    with it and you delete the text at that point.
    If you ran the DRC then clear the errors there as your text may be a mass
    of errors replicating your original text, if that's possible.
    If the text is in the library then you need to delete it at there in the
    package editor
    hth
    Warren
