EAGLE User Support (English) Modules in part names in board layout
  • Replies 7 replies
  • Subscribers 177 subscribers
  • Views 1361 views
  • board
  • eagle
  • names
  • modules
herrplanet
herrplanet over 11 years ago
Dear all,
with the introduction of the new modules we have been happily started to segregate our schematics into different modules, alas everything is fine. The designs included nested submodules with different depths. Now the module names are rather long for identification (Module_part_...) and not acronyms. The part names in the layout become unacceptably long,  since there is more than one layer using the offset is not an option. Is there yet any solution to this like module acronyms or an ULP which numbers all the parts on the board finally?
Alex
    On 11/3/2014 4:28 AM, Alexander Schultze wrote:
    Dear all,
    Alex
    Hi Alex,
    This is coming in 7.2. You'll be able to assign prefixes to modules, so
    for example a module named POWER can have a prefix like P. On the board
    you'll see something like P1:R1 instead of POWER1:R1. You can test it
    out in the latest beta 7.1.2.
    Best Regards,
    Jorge Garcia
    autodeskguest over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote on Tue, 11 November 2014 16:05
    Dear all,
    started to
    is
    depths. Now
    (Module_part_...)
    unacceptably
    an
    an ULP
    Alex
    Hi Alex,
    Best Regards,
    Jorge Garcia
    Jorge,
    I am running Eagle 7.3.0 x64 on Windows 7.
    I have set a prefix for each of my modules, but the full name of the module
    still appears on the board.
    Eg. I expect to see "PSU:C1" but instead see "POWER-SUPPLY-MODULE:C1"
    Do I need to take any extra steps to have the prefix applied on the board?
    Thanks!
    Jordan
    Jorge,
    Thanks!
    Jordan
    Hi Jordan,
    I have it working over here. Remember that the module prefix needs to be
    defined at the time in which you create the module. Is this what you did?
    With a little more information I think we can figure this out.
    Best Regards,
    Jorge Garcia
    Jorge Garcia wrote on Tue, 07 July 2015 17:10
    Jorge,
    the module
    the board?
    Thanks!
    Jordan
    Hi Jordan,
    be
    did?
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    No, I did not set the prefix when I created the module. After finding this
    thread, I went back and set the prefix by choosing "Properties" on the
    module.
    Jordan
    Bump!
    I've figured out a work around until this is fixed.
    (I'll assume your module is named "POWER-SUPPLY", the instance you wish to
    change is "POWER-SUPPLY1", and you've already set the prefix on the module
    itself to "P")
    In *.sch:
    Find & replace all instances of "POWER-SUPPLY1" with "P1". Repeat for any
    other instances. Don't try and replace "POWER-SUPPLY", it will break
    references to the module.
    In *.brd:
    other instances. This may be able to be shortened to "POWER-SUPPLY" but
    this is untested.
    I've needed to do this again, and looking back, all this does is change the
    NAME of the module. This can be done in EAGLE without the need to edit
    files, but it's kind of an annoying workaround.
    Is there any estimated time frame for fixing this bug? Updating to 7.4.0
    and changing the module's PREFIX doesn't have any effect.
    Cheers,
    Jordan
