EAGLE User Support (English) board size limit in Eagle 7.1.0 Windows Standard version?
  • Subscribers 189 subscribers
  • Views 3703 views
  • board
  • size
  • limit
Gentlemen,
I've bumped into a board size problem on my 7.1.0 Windows Standard version of Eagle.  It does not allow me to place components on a board outside of 100 x 160 mm.  I can (apparently) set the board size larger than 100 x 160 mm and I can place components within the 100 x 160, but when placing outside that area, it responds with "The Standard edition of EAGLE can't perform the requested action!  Some objects extend outside the allowed board area".  I thought the std version allowed boards up to 4x4 meters.
Am I missing something?
    autodeskguest over 8 years ago in reply to autodeskguest
    On 9/25/2017 4:32 PM, Rob Pearce wrote:
    On 25/09/17 19:44, Brian McKown wrote:
    I'm very new to Eagle (Standard Version) & I'm finding that I'm unable to place objects outside an area of about 4-inches by 3-inches.  That's considerably less than the stated 160mm X 100mm and I'm wondering if anybody has any wisdom they could impart to me to allow for me to work with the full PCB size.
    That sounds like the limits of the free version. Have you registered it
    and entered your license code?
    Hello Rob,
    I don't mean to hijack the thread. I just need you send me an e-mail to
    support@cadsoftusa.com. I have something of importance to discuss with you.
    Best Regards,
    Jorge Garcia
    We have a new forum here
    autodeskguest over 9 years ago in reply to bpmc
  • bpmc
    bpmc over 9 years ago
    Thanks in advance,
    Brian
  • e14candies
    e14candies over 11 years ago
    You really could make your board as large as you want, its just a lot of
    hassle, since you need to use the special placements to go beyond the
    limits.  It gets annoying when you are in a hurry, so its easier and
    beneficial to just get an upgrade & lessen the chance of making mistakes.
    The cost of any rework should certainly be a factor.
    Nope - the "Standard" edition is 100*160 - the "Professional" version is 4m
    • 4m - see their pricing sheet at
    http://www.cadsoftusa.com/shop/pricing/?language=en
    The "Standard" edition is "Limitations: 99 schematic sheets, 6 signal
    layers, 160x100mm routing area"
    mikey
    mikey
