In the past, there was a post that indicated you could move components
between sheets by holding down the shift while moving (
http://www.eaglecentral.ca/forums/index.php/mv/msg/18770/64100/ ), however
I can't seem to get that to work with version 6.5. From the "Help - Move",
it indicates "You can move part of a sheet to an other sheet of the same
schematic without affecting the board (in case Forward&Back Annotation is
active) by defining a GROUP that contains the objects you want to move,
selecting that group with the MOVE command and then switching to the
desired sheet, with the MOVE command still active and having the group
attached to the cursor. In the new sheet the MOVE command will be active
again and will have the previously defined group attached to the cursor.
Now place the group as usual, and all the affected objects will be
transferred from the original sheet to the current sheet." - that does work
(even if you only 'group' one part, but what happened to the shift+drag?
Was that deleted or am I not doing it right (my one sheet "overflowed" and
I wanted to just move some parts to the second sheet and finish drawing it.
While the group move does work it would be nice if you could just shift
drag parts to the next sheet too.
mikey
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
