EAGLE User Support (English) Creating schematic in parts
  • Replies 8 replies
  • Subscribers 179 subscribers
  • Views 804 views
  • sheets
  • labeling
  • schematic
Hello people.
I'm newbie in creating schematic. I'm asking this just because of the apearence. When I was building my schematic, I saw that it will be so big. So I share the schematic in two. But when I put the command "Label" to organize my sch, as you can see on the attach, this happend. How can I just put "SLC" and "SDA" without bars ou numbers because of the sheet? Thank all.
    in the schematic editor have a look at
         "Options / Set... / Misc / Xref lable format"
    Lorenz
    Former Member over 11 years ago in reply to autodeskguest
    http://www.element14.com/community/... So I share the schematic in two. But when I put the command "Label"
    Lorenz
    Hello again
    I have looked what you said to do but any modification has happend and continuos happening the same thing. Can you help me please?
    autodeskguest over 11 years ago in reply to Former Member
    Post a screen shot of your
    Here it is.
    On 8/01/2015 2:34 p.m., Flavio Espindula wrote:
    Here it is.
    If you type into the command line in the schematic editor:
    LABEL XREF OFF  Label
    Its all explained there.
    All the best
    Warren
    Hi again
    I have done what you said to do but look what happend on the attach. I think that Eagle cannot operate without this bug. I want to make my schematic without this numbers before the name of the label. But anyways, you helped me a lot. Can I solve this problem?
    On 9/01/2015 11:26 a.m., Flavio Espindula wrote:
    Hi again
    http://www.element14.com/community/message/136867
    See attached image.
    Do it that way
    All the best
    Warren
    Hello again.
    Thank you. Help me a lot. Now it is solved.
