EAGLE User Support (English) CK103X04 Rotary Switch 3 Pos 4 Pole 30* non shorting
  • Replies 11 replies
  • Subscribers 180 subscribers
  • Views 2402 views
Being new to all of this, I created a circut board using the CK103X04 .lib file. I used it, due to finding a post stating that it is a common layout for the switch. Now, I have come to find that I cannot locate or cross reference it at all. I already had 200 boards built & would rather find a compatible switch for the board, instead of throw them away. It has a similar layout to other switches, except for the upper common (wiper) pin is different.Does anyone know of a compatible switch for this? I have been dearching for days. The library that has it is "Switch.lbr"
Otherwise, can anyone confirm the typical Alpha-Tiwan designation in the libraries?
Thank you
from this frustrated newb...
Ed
    autodeskguest over 11 years ago +1
    On 01/16/2015 07:09 PM, Ed Grafton wrote: Being new to all of this, I created a circut board using the CK103X04 lib file. I used it, due to finding a post stating that it is a common layout for the switch…
    autodeskguest over 11 years ago in reply to Former Member +1
    On 17/01/2015 5:16 p.m., Ed Grafton wrote: I have the A30403RNCBE. It is a 3 pole 4 positoion switch by C&K. What I am getting at, is if you look at the CK103X04 in the Eagle library, on the 3 inner pins…
    Former Member over 11 years ago in reply to Former Member
    addendum:
    open brd/sch (reason: back/forward annotation must be active)
    forgot the right syntax:
    update; enter
    r
