EAGLE User Support (English) CK103X04 Rotary Switch 3 Pos 4 Pole 30* non shorting
  • Replies 11 replies
  • Subscribers 180 subscribers
  • Views 2403 views
Being new to all of this, I created a circut board using the CK103X04 .lib file. I used it, due to finding a post stating that it is a common layout for the switch. Now, I have come to find that I cannot locate or cross reference it at all. I already had 200 boards built & would rather find a compatible switch for the board, instead of throw them away. It has a similar layout to other switches, except for the upper common (wiper) pin is different.Does anyone know of a compatible switch for this? I have been dearching for days. The library that has it is "Switch.lbr"
Otherwise, can anyone confirm the typical Alpha-Tiwan designation in the libraries?
Thank you
from this frustrated newb...
Ed
    autodeskguest over 11 years ago +1
    On 01/16/2015 07:09 PM, Ed Grafton wrote: Being new to all of this, I created a circut board using the CK103X04 lib file. I used it, due to finding a post stating that it is a common layout for the switch…
    autodeskguest over 11 years ago in reply to Former Member +1
    On 17/01/2015 5:16 p.m., Ed Grafton wrote: I have the A30403RNCBE. It is a 3 pole 4 positoion switch by C&K. What I am getting at, is if you look at the CK103X04 in the Eagle library, on the 3 inner pins…
    "Switch.lbr"
    libraries?
    Thank you
    Ed
    http://www.element14.com/community/message/137603
    No help on finding a switch.
    The typical design flow should be something like this.
    1. check pricing, availability and delivery of possible parts you could.
    2. Download datasheets and check the part to your lib or make your own.
    3. Optional last check it so print 1:1 on paper and check that the part
    you ordered a sample of matches the layout.
    A sub note is don't trust any lib until you match it to the data sheet
    and move it into your lib.
    Paul
    Former Member over 11 years ago in reply to autodeskguest
    Thank you, Paul. The problem is that most of these companies, they do not show the 3 pole switch in the data sheets. I am waiting on some more info from Mouser.
    What I am hoping for is someone who has used this switch .lib & knows of the correct switch to plug in the hole. Also, this was in the library that comes with the Eagle software.
    I will definitely do more research next time.
    Thank you,
    Ed
    info from Mouser.
    Thank you,
    Ed
    http://www.element14.com/community/message/137605
    Seems easy enough.
    The library says its a C&K part
    The C&K website has plenty of documentation
    http://www.ck-components.com/a/rotary,10517,en.html
    You build up the part number from the required characteristics of the
    rotary switch i.e.  shaft diameter/metric imp and contact type etc.
    The part is available from Digikey where you can cross reference the
    manufacturer part number and no doubt others.
    All the best
    Warren
    Therein lies the problem. I was on the phone with the top guy at C&K. It is not & never has been their product. I have 200 of their switches that do not fit.
    Ed
    do not fit.
    Ed
    http://www.element14.com/community/message/137607
    Time for some clarity.
    Your post is entitled says CK103X04 Rotary Switch 3 Pos 4 Pole 30* non
    shorting. I see it as contradictory and thus have an issue with it.
    CK103X04 is an EagleCad numbering convension and not a manufacturer part
    number/name.
    The number of poles is always quoted first in switch parlance so I'm
    inclined to  interpret CK103X04 as a 3 pole 4 position switch. That is
    what the library package is and it appears to match the C&K diagram and
    so should fit the appropriate C&K switch.
    So how many poles (central) pins do your switches have?
    What C&K part number are they?
    Your initial post talks of one of the pins being different " ....except
    for the upper common (wiper) pin is different..."
    The C&K information does not indicate a different pin. All pins should
    be the same.
    If you design requires 4 poles then I don't expect there will be one
    that fits this 3 pole footprint.
    Warren
    I have the A30403RNCBE. It is a 3 pole 4 positoion switch by C&K. What I am getting at, is if you look at the CK103X04 in the Eagle library, on the 3 inner pins, the lower 2 are closer than each to the upper one.
    The CK103X04 will fit no switch in the C&K inventory, present or past. I am trying to find a switch that will fit the pin pattern, or I will have to do a new board that will cost more & delay production quite a bit
    You are correct, Warren, I typed it wrong in the title.
    Ed
    Ed
    Now I see your problem. The footprint has three issues.
    The inner pins are not spread evenly around their circle
    The diameters of both circles of pins are not quite the same as the C&K
    datasheet.
    I'd say the eagle footprint is in error (sadly). Hence the best practice
    of not using one you have not verified for yourself.
    I'm not confident you will find a part that will fit.
    Designers regularly have a couple of cheap prototype boards made first
    before before placing a larger order. That would have picked up this
    problem and there may be another yet to be discovered so consider the
    prototype board path.
    All the best
    Warren
    Former Member over 11 years ago in reply to Former Member
    OK, so I have redone the "Package" of the original switch & printed it out. It now fits with the alterations. I actually perforated the paper with the switch on a rigid piece of foam board. I also made the drill holes a bit larger for some fudge factor. Now, I have searched, but what I would like to do is replace the existing "Package" for the "switch.lbr (CK103X04.pac)" (Same extension). Is there a way to inject this new .pac file into the existing  device? Or, do I have to make a whole new .lbr file with the schematic & everything else?
    Thank you for all of your help,
    Ed
    Well, I saved the new file & "Updated" the library & all is good. Ordering new boards on Monday
    Thank you all,
    Ed
    command line:
    use *, enter
    update, enter
    update is done
    a DRC warning pops up, check the brd/sch
    voila, done
    r
