EAGLE User Support (English) Snap to grid components..how to?
  • Subscribers 177 subscribers
  • Views 800 views
Hi all, I'm new to Eagle
I started to put some components on the schematic, then wires and noticed they would not all align properly
Some components are exactly on grid pins and some others between grid pins. So when I'm wiring the pins
some won't attach properly, I find it tedious to always have to zoom right in to make sure the wires are touching.
The grid is set to 0.1 & 0.025, is there a way to fix or correct this?
I appreciate the help and support
thank you
    Yes. Use the standard grid.
    There is NEVER any reason to change the grid on the schematic nor to
    place anything off-grid (of course there is good reason for both on the
    board, where physical objects are represented, but not on the schematic,
    where everything is virtual).
    It has always been the case, and is a very common trap for newbies, that
    Eagle's schematic editor will not connect to pins that are off-grid.
    So don't do that.
    If you've designed any of your own library symbols and put any pins
    off-grid (or not on a 0.1" grid) then fix those first. Then update all
    libraries, snap all components onto the 0.1" grid on the schematic, and
    you'll be able to wire up properly.
    For snapping to grid, read "help move" and check out the
    behaviour.
