EAGLE User Support (English) element14 arduino micro board library
  • Subscribers 179 subscribers
  • Views 1214 views
  • board
  • layout
i have been trying to create a pcb board that includes a arduino micro soldered onto it.  i lay it out nice on the schematic but when i go to create the board it either isnt there or if it is it doesnt let me choose to put it on the board. (depends on which arduino micro i select from the library there are 2)  is there a way to get it to treat it like a ic or something so it will map it out as part of the board i enclosed examples of both
lighthouse2.zip
lighthouse3.zip
    mayybe i'm not using this right am i osting my question in the correct spot
  • robertmackinnon
    robertmackinnon over 10 years ago
    This should be like any other Eagle footprint.  In the Element14 library,
    there are two types of footprints provided for each Arduino model --
    <Arduino-name> and <Arduino-name>_EXT.  The former is the full device with
    schematic element and board footprint, the EXT is just the footprint.
    In the schematic, place the element and hook it up. When you switch to
    board view, it should appear in the window.
    - Robert
