EAGLE User Support (English) Simplified Solution's EAGLE to 3D part mapping
  • Subscribers 178 subscribers
  • Views 202 views
  • 3d
  • ulp
  • simplifiedsolutions
DaveYoung
DaveYoung over 10 years ago
Hi-
I'm exploring the EAGLE_to_3D ULP in conjunction with Simplified Solutions, and I'm stuck at the part mapping phase.
I have mapped all of the components in my design except the test points (which have no component as they are just pads/holes). I don't see anything that is a suitable part to map to a TH test pad.
I tried to just skip it and generate the 3D model, but it appears that isn't possible. What should I do now? Do I need to create my own 3D component? If so, how is that done? Is it possible to 'skip' mapping some components? Or perhaps mark them as a black box of height x?
Thanks!
    Dave, you can generated the 3D model without mapping all components. The app will put in bounding boxes where an actual component is not mapped.
    In the app you can also upload local models if you gave them. There are a couple upload options. If you need more info on this let me know.
    -Marc
