EAGLE User Support (English) Exporting PCB via IDF issues/concerns
  • Subscribers 178 subscribers
  • Views 271 views
  • eagle
  • idf
  • pcb
  • solidworks
  • export
I am attempting to export my PCB via the IDF ulp so I can import into Solidworks. he export seems to work and the boards import into solidworks. The only thing is none of the holes I have specified to use as a mounting point are in the imported part (drill holes do not show up nor do interior dimension layer lines). Is there a way to get this to show up properly?
(edit:) The only workaround is similar to the circle issue in the Dev Q&A where circle elements do not show up. I have to use the line tool to make a circle (multiple segments) around any drill holes I want to be visible.
-Kurt
    Kurt, could you share the .brd file you are using? I am the developer of the ulp. Ill take a look to see if I can see why they are not showing up.
    If you are not comfortable sharing the board on the forum let me know and I will reach out to you via email.
    Marc
    Former Member over 10 years ago in reply to Former Member
    Marc,
    I can not post the file publicly as it is for a product in development at this time. I could email it to you though.
    -Kurt
