EAGLE User Support (English) Export Schematic Image in High Resolution
  • Replies 15 replies
  • Subscribers 190 subscribers
  • Views 6594 views
  • board
  • layout
  • image
  • schematic
  • export
Hello all.
I'm here to ask a question. I'm a member of a big project and to not confused about how the project works, I will do a PDF file explaining how all project works. But when I export the shematic image by using comand File>Export>Image, the image lose almost every high resolution. Whatever if I put 1200dpi, the image still looks horrible. Can anyone help me about this?
    autodeskguest over 11 years ago in reply to e14candies
    On 6/27/2015 11:19 AM, Hoyt wrote:
    That's one of the potential ongoing problems of requiring an external ulp
    versus having the required functionality built into Eagle itself. Many
    common tasks that could be included are not.
    Hi Hoyt,
    In this case, the issue is likely because the user hard coded scale
    factors, instead of using the conversion functions that ship with EAGLE.
    ULPs that make use of those functions are completely portable between V5
    and newer because the functions have already compensated for the
    improved resolution.
    I can't find the origin of this thread, but the high resolution images
    can be achieved without the use of a ULP. You can use the CAM processor
    or the export image option under the file menu.
    hth,
    Jorge Garcia
  • e14candies
    e14candies over 11 years ago in reply to e14 Contributor
  • Morosh
    Morosh over 11 years ago in reply to e14 Contributor
    this is because since version 6, the internal units have changed. The author should update the ulp, I'll have a look when I have time.
    Other, if can save the board backwards to version 5, it'll works.
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Hi
    I found a error when I tried to convert .brd on .eps. See the image.
    e14 Contributor over 11 years ago in reply to Morosh
    Hi again.
    I have no words to say else, thank you so much, It was I looking for.
  • Morosh
    I made a mistake, there is a newer one epsdraw_411:
    http://www.cadsoftusa.com/downloads/file/epscdraw_411.ulp
    HTH
    Thanks a lot. But it is happening an error as you can see on the image.image
  • Morosh
    download "http://www.cadsoftusa.com/downloads/file/epsdraw.ulp"
    it'll convert schematic to eps format, that you can use in word: insert -->picture --> from file --> xx.eps
    HTH
    e14 Contributor over 11 years ago in reply to autodeskguest
    Hi again
    I use Windows 7 with office 2013.
    autodeskguest over 11 years ago in reply to e14 Contributor
    On 16/06/2015 6:44 a.m., Flavio Espindula wrote:
    Hi
    I am using Eagle 7.2.0 version. Can you explain better how to do this
    process?
    http://www.element14.com/community/message/152727
    Which OS are you using? If a MAC you should use a later version than 7.2
    All the best
    Warren
