EAGLE User Support (English) Export Schematic Image in High Resolution
  • Replies 15 replies
  • Subscribers 190 subscribers
  • Views 6593 views
  • board
  • layout
  • image
  • schematic
  • export
Hello all.
I'm here to ask a question. I'm a member of a big project and to not confused about how the project works, I will do a PDF file explaining how all project works. But when I export the shematic image by using comand File>Export>Image, the image lose almost every high resolution. Whatever if I put 1200dpi, the image still looks horrible. Can anyone help me about this?
    e14 Contributor over 11 years ago in reply to autodeskguest
    Hi
    I am using Eagle 7.2.0 version. Can you explain better how to do this process?
    autodeskguest over 11 years ago in reply to e14 Contributor
    On 15/06/2015 6:45 p.m., Flavio Espindula wrote:
    Hi
    Thanks. But I tried this process. The problem when you go PRINT > PDF
    FILE is you cannot transfer this image to word, for example, to make a
    manual guide using this image. Do you have any sugestion?
    http://www.element14.com/community/message/152641
    You have not said which version of eagle are you using. That may be
    important.
    I checked this using 7.2.2 (Win7) and can paste high resolution images
    into a word(2010) doc from the clip board or insert a png image.
    Using 300dpi was good for me.  So I'm not experiencing your problem
    HTH
    Warren
    Hi
    important.
    HTH
    Warren
    Hi
    Thanks. But I tried this process. The problem when you go PRINT > PDF FILE is you cannot transfer this image to word, for example, to make a manual guide using this image. Do you have any sugestion?
    On 15/06/2015 5:11 p.m., Flavio Espindula wrote:
    Hello all.
    help me about this?
    http://www.element14.com/community/message/152639
    Hi
    I believe what you should be doing is to Print > Print to pdf
    HTH
    Warren
