EAGLE User Support (English) Eagle ERC error.....
  • Replies 7 replies
  • Subscribers 177 subscribers
  • Views 847 views
Hi All,
I'm wrapping up a new design, and getting an error when I run ERC using
Eagle 6.4.0. The specific error is: "Uninvoked MUST gate G$2 in part FRAME1
(FRAME-LETTER)". I understand that ordinarily this type of error can occur
when some (unused) pins on multi-gate parts are left unconnected. In my
case, there are no multi-gate parts in the design at all. The only thing
that I can think of is that this design was originally created by copying
another design, and maybe there is a hidden 'scrap' left over that is
causing the error?
Any suggestions to eliminate the issue?
    On 29.06.2015 23:30, jmorley@endeavour-usa.com wrote:
    Hi All,
    causing the error?
    Did you try to type "invoke frame1" to see if something unexpectedly
    pops up on the gate list?
    On 30/06/2015 9:30 a.m., jmorley@endeavour-usa.com wrote:
    Hi All,
    causing the error?
    Hi  john
    You should upgrade to the last version of 6.
    6.4 was not a good version.
    Download from ftp://ftp.cadsoft.de/eagle/program/
    Warren
    autodeskguest over 10 years ago in reply to autodeskguest
    Hi Morten,
    Actually, that's a 'new one' for me! I just tried it, and I get:
    G$1   LETTER_L   Next   0   1 (greyed out)
    G$2   DOCFIELD   Must   0   1 (active)
    It's certainly more information, but I'm not sure what to do with it? I
    tried a 'Delete G$1' and a 'Delete G$2', but gort an 'unknown part' error
    for each.
    Hi Warren,
    After I finish this job, I plane to upgrade to v7!
    Good idea or not?
    Unless there is something you really need in V7, or any new release of any
    product,  then save the money. You can normally afford to skip one
    release.
    Many have been disappointed in the limited feature growth that v7
    provided.
    I suggest you read the release notes from your version through to the
    latest beta versions, and any subsequent release. That will give you an
    indication what has been repaired or the features that get inserted at
    point releases.
    HTH
    Warren
    Hi All,
    This is still an outstanding issue for me, and one that I'd like to
    understand/solve for the future! My board is done, and off to the fab with
    (presumably) no issues, but still this ERC error is out there.....
    Again, when I use the 'Invoke Frame1' command as suggested, here is what I
    get:
    Thoughts?
    Hi
    Your board should not be affected by the error you have.
    I suspect that you have a frame on the schematic but some how the Docfield
    is not there when it 'must' be. So add it from the invoke dialog.
    If it is already there, I would delete the frame and re add it.
    HTH
    Warren
