EAGLE User Support (English) Schematic: How to paste multiple times? Group copy procedure?
  • Subscribers 187 subscribers
  • Views 3357 views
  • copy
  • schematic
  • paste
gwideman
gwideman over 11 years ago
Two questions regarding copy and paste. I have looked at the manual, and googled, but haven't come up with an answer.
1. Ordinary and Group copy-paste. I can get both of these to work to paste once, but in both cases I have not discovered how to paste the copied item(s) multiple times. I mean:
  • Select and copy the item(s) (single or group)
  • Move the mouse somewhere and paste
  • Move the mouse somewhere else and paste.
How do you do that? For me, what happens after left-clicking to perform the first paste is that Schematic seems to forget that there's anything to paste. I suspect there's some key/mouse button combo that does what I want, but what is it?
2. Having said the above, I feel I don't fully understand even the "Group copy, paste once" procedure: My current procedure is
  • Press the Copy tool button
  • Press the Group tool button
  • Drag a rectangle around the objects to be copied
  • At this point I would have thought the operation would be ready, but it isn't. The status bar unhelpfully suggests "Left-click to select object to copy (why? I've selected a group, and it's highlighted.) Instead I have to additionally right-mouse on something in the selected group, and from the popup menu select Copy:Group.
    • NOW the mouse drags around a copy of the group, and I can place it with left-click.
    • So why do I need to tell Schematic twice that I'm performing a Group Copy? I feel I must be missing something
Please illuminate me!  Thanks!
-- Graham
[reposted marked as a question.]
  • gwideman
    0 gwideman over 11 years ago in reply to autodeskguest
    @Warren -- good to know. Though the classic "Paste" icon isn't much more comprehensible.
    @ Lorenz: OK, interesting.
    0 autodeskguest over 11 years ago in reply to autodeskguest
    warrenbrayshaw wrote:
    On 17/07/2015 8:32 p.m., Graham Wideman wrote:
    (Side issue: Turns out that the Paste button, which indeed I had not
    found, is the one whose icon has a large yellow circle next to a small
    black circle. What mnemonic is that?)
    Seems you are a new user. The old hands turn off the new 'load of crap'
    icons and revert to the previous icon set.
    Control Panel > Options > User Interface... > Classic Icon style
    and most likely revert the right-click action from 'contexr menu' back
    to 'group action'
       set Option.ToggleCtrlForGroupSelectionAndContextMenu 1
    Lorenz
    0 autodeskguest over 11 years ago in reply to gwideman
    Thanks for your answer Warren. A couple of followup points.
    1. Following your Group Copy procedure:
    Click the Paste tool
    Ahh! there we go, lots of copies.
    HTH
    Warren
  • gwideman
    (Side issue: Turns out that the Paste button, which indeed I had not found, is the one whose icon has a large yellow circle next to a small black circle. What mnemonic is that?)
    Actually, I get only one copy (that is, one paste), and then the paste tool button (and paste mode) deselects. I can reselect the paste button, and that's good for one more paste. And so on. That's better than nothing, but is there a mode where I can just keep pasting more copies without having to reselect the paste button each time, just like when dropping components using the Add tool?
    2. I get the action you describe only after Group Copy, and not after normal (single component) Copy. Am I missing something, or does regular copy follow a paradigm so different that it does not retain the copied object after the first paste?
    > You can select the copy before the group and Eagle nicely keeps it selected after the group.
    Is this a benefit that I'm not understanding?
    -- Graham
    group, and from the popup menu select Copy:Group.* NOW the mouse drags
    Eagle use is akin to reverse Polish notation. You select the action then
    apply it to the object.
    To copy a group there must be one set up so your order should be
    Select Group tool
    Make group
    Select Copy tool
    Select the item to copy, which is the group in this case.
    ..and wow a copy is stuck to the mouse. Quick, place it where I want it.
    Hmmmm, I only got one copy, bother. "What's that?" the manual and help
    say 'copy' copies to the clip board. How can I get it from there?
    HTH
    Warren
    p.s. My torch is not bright enough to illuminate you from here
