EAGLE User Support (English) How Can I Import PADS Files into Eagle ?
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 4737 views
  • .brd
  • eagle
  • pads
  • pcb
  • mentor
  • convert
  • mentorgraphics
  • .sch
  • import
I'm new to Eagle, but find it pretty easy to use and I can create PCBs pretty quickly that my PCB fab in China can make in a few days.
I have some PADS (MentorGraphics) .sch and .pcb files that I want to import into Eagle.
I have searched many forums, visited the CadSoft support page and even asked CadSoft Tech Support, not much success so far.
A colleague managed to import the original .sch and .pcb files into PADS, and exported the project as an ASCII file (also .dxf - but I'm not certain whether that helps) ...
Unfortunately, Eagle only imports ACCEL ASCII - aka P-CAD ASCII.
So ...
I have PADS .sch, .pcb, .asc and .dxf files, and just want to get the PCB (also the schematic if possible) into Eagle, so I can modify the original layouts.
I've researched for days and tried everything I can think of ...
I even tried to import the PADS files into Altium, hoping there might be a way of converting them there.
But neither the .sch and .pcb files, nor the ASCII or .dfx  files, import correctly (or at all).
Ditto por KiCad, DipTrace etc.
I know this topic has been addressed a few times in the element14 forums, but I've been unable to find a solution, apart from this thread ...
How to import PADS component library? The import-pads-powerpcb-v5.ulp seems doesn't work.
Unfortunately this thread doesn't refer to the original source - or the ULP.
Does anyone have any ideas / suggestions ?
I'd really appreciate any assistance ...
Many thanks,
Gary
    Hello Gary
    Can you send your files to us?
    Maybe we can help you, we are one high quality, high precision and special Printed circuit boards value-added services provider in China.
    Best regards
    Jun Lee
    Tel: 86-755-29760917
    Fax: 86-755-23114189
    Email: sales@jxtpcb.com
    Web: www.jxtpcb.com
    LogicSwap can Import PADS Schematics and Board Designs into EAGLE as a
    service.
    If you send us the files, we will send you a quote.
    If there is enough interest from the community we will consider making this
    into a product.
    mailto:mwilson@logicswap.com
    0 autodeskguest over 11 years ago in reply to eduardodemier
    Am 07.10.2015 um 15:38 schrieb eduardodemier:
    Hi.
    I have the same problem. A consultant did a design for me and now I need
    to convert it to EAGLE.
    I suppose there are two steps. First export from pads into a feasible
    ASCIII format and then import this in EAGLE.
    Any Hints?
    EAGLE comes with an import ACCEL ASCII format ULP. Maybe this helps?
    As far as I know Pads can export in ACCEL-ASCII format.
    Richard Hammerl
  • eduardodemier
    0 eduardodemier over 11 years ago in reply to e14 Contributor
    Hi.
    Any Hints?
    0 e14 Contributor over 11 years ago in reply to clem57
    Hi Clem,
    Thanks again for your post …
    Yes, I have already managed to export a .dxf file from PADS - but it doesn’t open in Eagle.
    So - I don’t know whether the issue is on the PADS side or the Eagle side.
    Any further ideas would be great - tanks.
    Best regards,
    Gary
    Hi Clem,
    Many thanks for your reply …
    Yes, as I think I mentioned in my post, I can open the files in PADS - and the Free Viewer opens the files OK.
    So I know the files are intact - the issue is how to convert them into a form readable by Eagle.
    Any further ideas would be greatly appreciated.
    Best regards,
    Gary
  • clem57
    0 clem57 over 11 years ago in reply to clem57
    Assuming the viewer above works, try Converting Gerber files from PADS to DXF for a format useful to Eagle,
    C
  • clem57
    Firstly I would try Free PADS PCB Schematic Viewer - Mentor Graphics and check are they valid? If so, you know the type at least.
    C
