EAGLE User Support (English) Copy/paste group to different layer in Library package editor?
  • Subscribers 187 subscribers
  • Views 973 views
  • copy
  • group
  • layers
gwideman
gwideman over 11 years ago
In the Library's package editor, how do you (group) copy from one layer to another?
  • I can group copy and paste to the same layer
  • I can group change layer
  • But.. these two things need to happen in one single operation.
In my case, this is useful for copying silk screen graphics from one side to the other.
What's the method? Thanks!
-- Graham
  • gwideman
    0 gwideman over 11 years ago in reply to gwideman
    AH-HAH.. that worked!
  • gwideman
    This reply is an experiment to see if I can get rid of the "Assumed Answered" status of this thread.
    1. I post this reply.
    2. I mark this as the correct answer (displacing the assumed answered status)
    3. I UNmark this as the correct answer. Will this move the thread to Unanswered status, or revert to assumed-answered?
    -- Graham
    0 autodeskguest over 11 years ago in reply to gwideman
    On 15.08.2015 11:13, Graham Wideman wrote:
    I've now attempted to follow this sequence, and I can't carry it out.
    1. Select a group.
    2. Copy. I assume "Cadsoft Guest" meant Group Copy, as plain Copy simply
    copies a single element.
    Yes I did (and not sure why cadsoft shows me as guest. The NNTP server
    where I posted has my name. But I guess its a known bug).
    3. At this juncture, a copy of the group is "stuck" to the mouse
    pointer. So I can't proceed to perform the "Change layer of existing",
    so far as I can tell.
    Yes, it will stick to mouse pointer, but you can cancel the "auto
    paste". The copied stuff will be in the paste buffer and you can click
    paste (icon below the group icon) at a later time. Even multiple times.
    BUT:When copying a group of nets from the BOARD EDITOR will generate new
    netnames on paste, so my initial advice was for the library PACKAGE
    EDITOR only.
  • gwideman
    0 gwideman over 11 years ago in reply to autodeskguest
    CadSoft Guest wrote:
    to another?
    side to the other.
    What about
    -group
    -copy
    -change layer of the existing
    -paste
    1. Select a group.
    2. Copy. I assume "Cadsoft Guest" meant Group Copy, as plain Copy simply copies a single element.
    3. At this juncture, a copy of the group is "stuck" to the mouse pointer. So I can't proceed to perform the "Change layer of existing", so far as I can tell.
    I hope Cadsoft Guest might detail how this sequence should work?
    Thanks!
  • gwideman
    What about
    -group
    -copy
    -paste
    Hmmm, I'll have to play with that to see how it works.
    In general I don't like the idea of messing with the existing elements while also having fingers crossed that the subsequent paste will reinstate the components that got changed.
    Too often, Eagle doesn't do what I expected  -- some elements turn out not to be eligible for copy, or for paste, or some other thing goes wrong. And having both changed the layer of some elements, then pasted some elements "over top", and by that time probably the group selection is probably no longer in effect... arrg, I need aspirin... etc.
    But I'll give it a try and see if it's tractable.
    -- Graham
    to another?
    side to the other.
    What about
    -group
    -copy
    -paste
