EAGLE User Support (English) Eagle 7.3.0 Standard &  Windows 10 64 bit Printing Crash
  • Subscribers 187 subscribers
  • Views 886 views
  • windows10
  • print
  • crashing
glenn@clanlogan.info
glenn@clanlogan.info over 11 years ago
I have Eagle 7.3 installed and working well in every respect except when I try and print anything (including just bringing up the print setup box) Eagle just crashes out - no error.  This happens on any printer set as the defualt including the PDF writer.
Any idea how I debug this - are there log files ot look at?  Its a Windows 10 64bit PC.
I can print fine from other apps.
Glenn
  • geralds
    0 geralds over 11 years ago in reply to glenn@clanlogan.info
    Hi Glenn,
    my pleasure.
    What i remember, the dell hardware would a little bit tricky using it.
    My favorite laser printers are  Konica-Minolta and HP.
    With this printers you can also print the pcb layout für etching.
    The wire lines will be printed very pretty fine.
    Regards
    Gerald
  • glenn@clanlogan.info
    0 glenn@clanlogan.info over 11 years ago in reply to geralds
    Thanks Gerald,
    That narrowed it down I removed my old laser printer dirver (Dell 3010cn) which works well in Windows 10 for every other app but causes an instant crash for Eagle - even trying to open the properties page does it.
    Latest driver is 2011 which dell released for Win7 and no support since. I tried various inputs - Ethernet, USB, via a shared from anothe rPC. As soon as that driver is installed eagle wont do any printing.
    Anyway I know what the problem is now!
    Regads
    Glenn
  • geralds
    i also work with Win10/64. Eagle works well, printing to a printer also to pdf file.
    Please look for the drivers.
    Win10 and Eagle are working well together.
    best regards
    Gerald
    imagetimer-bi-relais-pcb.pdf
